nc system board QX084
billet cnc man
Aug 9, 2019
Hello
just after some help ,
changed board QX084 in a mazak qt20 t plus after it failed , machine ran fine , it did put up a battery alarm , but machine ran fine ,
turned it off at night , next day it will switch on but has alarm 202 no hydraulic power, went to check battery and wasnt one fitted in new board so checked and installed old one and still no full power up , have i lost some parameters from having no battery back up ???
any ideas
thanks
kev
Without battery backup, yes you have lost the parameters.
MEAU in Chicago can provide you a procedure to re-initialize the control.
Which will clear all your programs, tool data, etc., so back all that up if you can.
(Worst case, take pictures of the screens.)
nc board battery fail,
:)hi thanks for your reply ,you were right,
all sorted now apart from bar pusher not working fully ,(program) got to point were it has pushed bar to bar stop, then stops, should push out to length,then close jaws ,
thanks
kev
