nc system board QX084
Likes Likes:  0
Results 1 to 3 of 3
    Aug 2019
    UNITED KINGDOM
    Default nc system board QX084
    Hello
    just after some help ,
    changed board QX084 in a mazak qt20 t plus after it failed , machine ran fine , it did put up a battery alarm , but machine ran fine ,
    turned it off at night , next day it will switch on but has alarm 202 no hydraulic power, went to check battery and wasnt one fitted in new board so checked and installed old one and still no full power up , have i lost some parameters from having no battery back up ???
    any ideas
    thanks
    kev
    Sep 2006
    Abingdon, VA
    3,544
    4778
    3442
    Without battery backup, yes you have lost the parameters.
    MEAU in Chicago can provide you a procedure to re-initialize the control.
    Which will clear all your programs, tool data, etc., so back all that up if you can.
    (Worst case, take pictures of the screens.)
    Aug 2019
    UNITED KINGDOM
    Default nc board battery fail,
    Quote Originally Posted by cnctoolcat View Post
    hi thanks for your reply ,you were right,
    all sorted now apart from bar pusher not working fully ,(program) got to point were it has pushed bar to bar stop, then stops, should push out to length,then close jaws ,
    thanks
    kev
