need help locating o-ring s for qt200
Likes Likes:  0
Results 1 to 4 of 4
    Feb 2007
    Joplin, MO
    369
    85
    17
    Default need help locating o-ring s for qt200
    I am looking for the O-rings for a 1999 Mazak qt200 for the actuator.
    The actuator is a Logansport Matsumoto ZKP150/52-22-01m.
    I am trying to find what size the O-rings are so I can source them someplace besides the OEM. They want $375.00 for 10 O-rings.
    Any help is appreciated.
    Michael
    Jun 2015
    Minnesota
    534
    9
    186
    With Mazak being Japanese they're probably JIS O-rings. If they're mostly small just buy a JIS kit. If not go to Maryland Metrics or The O-Ring Store. The O-Ring store sells smaller quantities though MM may have more sizes. Can't recall. Many times even buying a minimum quantity is cheaper then buying OEM.
    Jul 2010
    Rochester, NY USA
    2,261
    10
    536
    I would start with the Mazak parts book.
    Most of the time the size is listed there.
    I use Metric Seals @ 317-896-3555,
    Bill
    Feb 2007
    Joplin, MO
    369
    85
    17
    Thanks guys.
    The guy that helped me take it apart suggested taking them to Hyspeco which is 3 blocks away. They have a cone for sizing.
    It cost $10.27 instead of the $375.00 from the OEM.
    Again thank you for the help.
    Michael
