Need help locating a solenoid for a 1999 Mazak qt200
Results 1 to 5 of 5
    Feb 2007
    Joplin, MO
    368
    85
    17
    Default Need help locating a solenoid for a 1999 Mazak qt200
    Hi guys,
    I am trying to replace a turret clamp solenoid for a 1999 Mazak QT200
    The part number is D1VW001CNQW.
    Hyspeco is giving me a 5-6 week delivery and I am needing it sooner.
    Anyone have an alternative supplier?
    Michael
    Jul 2009
    Munster, In. USA
    2,347
    482
    724
    I have purchased from Detroit Coil, now Rossdecco.
    ROSS Decco(R) – Industry Leading Solenoids
    Here I used just the coil as the dimensions, voltage, and specs matched the application for an hydraulic solenoid.
    Other but may be pricey, Namco
    Nuclear Qualified & Heavy Duty Limit Switches, Sensors & Solenoids | NAMCO
    Just sources and purchased for a non-Mazak machine.
    John
    Sep 2005
    il.
    6,653
    30
    1225
    all world in chicago Illinois has alot of parts and can cross the parker numbers
    815-943-9111
    that's a common directional valve with standard mount
    from that number all world can probly match to something in stock
  4. Likes cnctoolcat liked this post
    Sep 2005
    il.
    6,653
    30
    1225
    if you can look at this and figure out what you have from the diagram on the valve you can probly get it out of McMaster carr forin one day
  6. Likes cnctoolcat liked this post
  7. #5
    Sep 2005
    il.
    6,653
    30
    1225
    or not
    good luck
