novation1
- Apr 3, 2017
- Columbia Station, Ohio USA
Hi All,
I'm having a programming problem with my machine. It's a QT-8 SP with a T-2 control. I won't let me program more than one line in a program. I entered a small program straight out of a Mazak programming manual, except for converting the dimensions to inches. Attached are pictures of the program. It had only 5 lines. If there are any more than 1 line I get an "illegal cutting point" error. I started with the 5 lines and erased one line at a time to see if the error would go away. It didn't go away until there was just 1 line left. I used the example from the manual just to see if what I was originally trying to input was way off. I thought it just wouldn't let program a taper.
Anyone know which card in the control the geometry is generated from? Or any other logical step I could take to track this problem down. It had been working okay until a couple of days ago. Of course it never quits working until you really need it not to! Any help would be greatly appreciated.
