Need a sample 640t SQT100mst bar program, EIA, sub spindle sync?
Likes Likes:  0
Results 1 to 6 of 6
    Mar 2008
    Paso Robles, CA
    301
    13
    Default Need a sample 640t SQT100mst bar program, EIA, sub spindle sync?
    Hello,
    Just doing a simple bar program with a SQT100MSY, 640t.
    Turn the end
    sub spindle clamp & sync.
    reposition
    repeat
    We know how to part off and end work, we use a 9001 sub-program for that.
    Thank you!
    Mike
    Jan 2012
    indiana, usa
    197
    48
    T0121.02G0G40(TRANSFER)
    M306(SUB CHUCK OPEN)
    G99G18
    G28U0.
    G0Z0.
    G0B-16.
    G97M3S50
    M358(AIR BLOW)
    M5
    M200
    G0C180.(POSITION MAIN TO 180 DEG)
    M300(CONTROL SUB)
    M360(ACTIVATE SUB CLAMP)
    M319S0.(POSITION SUB TO 0 DEG)
    M502(SYNC SPINDLES)
    G1G98B-17.70F50.(FEED SUB TO CLAMP POSTION)
    M307(SUB CHUCK CLOSED)
    G4P0500
    M6(OPEN MAIN CHUCK)
    G28B0.
    G0Z6.
    M505(RELEASE SYNC)
    M359(SUB UNCLAMP)
    M318(REPOSITION SUB SO IT UNCLAMPS)
    M302(TURN OFF SUB CONTROL)
    M202(MAIN SPINDLE CONTROL)
    M1
    Hope this is what you are looking for.
    Mar 2008
    Paso Robles, CA
    301
    13
    Chad 883
    Thank you very much, I am a little further on now, but what I am looking for the most is not in your program.
    Below is where we are at, spindles synced, pullout is complete, the issue now is that when I go in to machine another section of the bar it is not moving the Z zero with the bar pull, any comments?
    Your program is close but just looking at the spindle sync, that is M511 but whatever strategy I am missing is probably something pretty basic. We will need to move the part out 3 or 4 times, it is plastic and we are putting groves on the OD and at the end we will end work it in the sub.
    O00000001
    G424L0Z0.1866
    G424L1
    G424L2A0B0C0D0E0F0
    G424L3H0I0.K0.M0.N0P0Q0
    G424L4H0I0.K0.M0.N0P0Q0
    G424L5
    G424L6
    G424L7
    G424L8
    G424L9
    G424L10
    (Y80428 MSY-1)
    (80428 B CUSTOMER 130 OP#1)
    (USE .75 maerial)
    (2.6 out of chuck)
    (chuck pressure is 100 PSI)
    (####Z SET UP POSITION and put it here ####)
    #101=.1
    #102=2.0 (first pull distance)
    #103=.1
    #500=13.580(transfer position)
    #555=0.099(Z CORRECTION FOR SUBSPINDLE)
    G99
    G18
    G53
    G50S1200
    G0G28Y0.
    G0G28U
    G0G28W
    ((.016 RAD FINISH O.O.)
    T0202G97S800M3M8
    M202(TURNING MODE)
    G0G28Y0.
    G0G28U
    G0G28W
    G0G28B0.
    M01)
    (TRANSFER PULL)
    M5
    M202(TURNING MODE HEAD 1)
    G112 M202(TURNING MODE Head 2)
    M358(AIR BLAST)
    M540(TRANSFER CHUCK MODE)
    M306(SPINDLE 2 CHUCK OPEN)
    G98G4X1.
    G0B-[#500]
    G112 M508
    G98G31 B-[#103+#500]F3.
    G111
    M307(SPINDLE 2 CHUCK CLOSE)
    G98 G4X1.
    M6(CHUCK 1 OPEN)
    G98G4X1.
    G1B-[#500-#102]F100. (first pull distance)
    M7
    G98G4X1.
    M541(TRANSFER MODE OFF)
    M511(SPINDLE SYNC MODE)
    G97S500M3
    G98G4X1.
    G50S1200
    G0G28Y0.
    G0G28U
    G0G28W
    (.016 RAD FINISH, SAME AS ABOVE)
    T0202
    G53
    G50Z+[#102] (FIRST TRANSFER DIATANCE)
    G112M202
    M202M300
    G18
    G50S1800
    G112G97S900M3M8
    G0Z-2.
    Y-.1
    Y0
    X.51
    G1Z-3.F.007
    X.75
    G0G28U
    G0G28Y
    G0G28W
    M5
    M512
    M30
    Jan 2012
    indiana, usa
    197
    48
    Only thing I can see, and I'm not sure it matters, is the G50Z line. I use G50 W-[#102]. Just be careful that it is shifting the offset in the right direction.
    Mar 2008
    Paso Robles, CA
    301
    13
    Chad883,
    G50w, I have seen that and I will change it, thank you. My next problem is getting the spindles to stop tougher, they are synced but when they stop they seem to be do some kind of independent correction/c axis homing, I need to fix that, any hints?
    Jan 2012
    indiana, usa
    197
    48
    I usually sync them with 1 of the chuck open so they don't fight. May not be necessary.
