Hi,
I'm suffering with a grooving problem. Making a grove with starting 3mm radius start-x 80. start-z 10. end-x 70. end-z 10 endradius 3.
When you do check toolpaths it all seems normal it does rough pass and fine pass from left and right as it should. But when checking simulation it just enters in the middle of the groove as a rough pass and then stops without any message or anything. And it does the same thing when you run live it stops in the middle of the groove.
My overlap parameter U44 is set to 10. And this machine is metric so I'm not sure if that means 0.010mm of overlap allowed?
Can someone clearify this for me? I just bought this machine and its quite frustrating, can't find anything wrong in my program. And does the "toolpath check" and "simulation" have diffrences in them in more cases than this ?
