OD grooving cycle #1 problem mazatrol T2
Results 1 to 18 of 18
    Aug 2016
    SWEDEN
    35
    Default OD grooving cycle #1 problem mazatrol T2
    Hi,
    I'm suffering with a grooving problem. Making a grove with starting 3mm radius start-x 80. start-z 10. end-x 70. end-z 10 endradius 3.
    When you do check toolpaths it all seems normal it does rough pass and fine pass from left and right as it should. But when checking simulation it just enters in the middle of the groove as a rough pass and then stops without any message or anything. And it does the same thing when you run live it stops in the middle of the groove.
    My overlap parameter U44 is set to 10. And this machine is metric so I'm not sure if that means 0.010mm of overlap allowed?
    Can someone clearify this for me? I just bought this machine and its quite frustrating, can't find anything wrong in my program. And does the "toolpath check" and "simulation" have diffrences in them in more cases than this ?
    Apr 2014
    AUSTRALIA
    619
    233
    152
    Post a pic of your programming too
    Sent from my LG-H815 using Tapatalk
    Aug 2016
    SWEDEN
    35
    Here you go. Its not english but you might be abel to read anyway.
    Apr 2014
    AUSTRALIA
    619
    233
    152
    How wide is your grooving tool? I would have thought that would throw an illegal width error. The width needs to be groove width plus radius I'm pretty sure.
    Aug 2016
    SWEDEN
    35
    The slot is 10mm wide as you see in the picture. And the grooving too is 3mm wide and 12mm long and 0 radius compensation.
    Apr 2014
    AUSTRALIA
    619
    233
    152
    Try making your groove width 15 just as a test and see what it does.
    Aug 2016
    SWEDEN
    35
    Quote Originally Posted by xa-mont View Post
    Same problem
    It just freezes in the middle of the groove. And no error. What about the U44 parameter is that one correct?
    Apr 2014
    AUSTRALIA
    619
    233
    152
    Shouldn't really mate. But for the sake of argument, try changing it to 2000 (2mm) and see what the simulation gives you
    Aug 2016
    SWEDEN
    35
    No diffrence something else must be wrong. Maybe in the parameters. I manage to find that it goes as deep as i type in the pecking deepth .
    Apr 2014
    AUSTRALIA
    619
    233
    152
    Does the peck retract parameter have 0 in it
  11. #11
    Feb 2015
    SWEDEN
    605
    106
    291
    Try write a new program.
    Sometimes if you delete rows and/or changing from one processtype to another processtype Mazatrol T2 behave strange.
  12. Likes ManualEd liked this post
  13. #12
    Feb 2015
    SWEDEN
    605
    106
    291
    Start radius is 3mm and end radius is 3mm but groove is only 5mm Deep.
    try lower the radius or do the groove more then 6mm deep.
  14. Likes xa-mont, GP Tech liked this post
  15. #13
    Apr 2014
    AUSTRALIA
    619
    233
    152
    Quote Originally Posted by benganboll View Post
    i didn't think of the depth.
  16. #14
    Aug 2016
    SWEDEN
    35
    Hi,
    I just want to share the solution I found to this. It was not about the depth vs radius etc. Its was the parameter U45 that was set to "0". Its the grooving retract parameter. That explains why it did not work. But still intressting when you press "toolpath check" it showed the correct grooving cycle toolpath on the screen, but in simulation (and when running) it just freezed after end of first cut. Hehe.
  17. Likes xa-mont, Philabuster liked this post
  18. #15
    Feb 2015
    SWEDEN
    605
    106
    291
    U45 sets the feedrate (wonder why that was set to 0).
    The toolpath check does not take any feedrate into calculation, only the endpoint of all moves.
    The simulation simulates all the feedrates.
  19. Likes Philabuster, xa-mont liked this post
  20. #16
    Aug 2016
    SWEDEN
    35
    I just set it to about 1000. And it seems about right. What do you have on youre machine?
  21. #17
    Feb 2015
    SWEDEN
    605
    106
    291
    Quote Originally Posted by panscan View Post
    At the moment I only have access to my parameters from our QT10ATC M/C and U45 is set to 1000
  22. #18
    Apr 2014
    AUSTRALIA
    619
    233
    152
    mine is 2000 on my QT10n
