Parameter for origin
benganboll
Hot Rolled
Feb 23, 2015
Sweden Östersund
I am going to put in new ball screws in both Z axis on a Multiplex 6200Y with fusion 640T.
My ide is to take the current Z offset of tool 1 and after changing ball screw change the parameters to come as close to the same numbers as possible.
Will that give all programs the correct Z offsets?
What paramer should I change?
To be 100% sure I did a mechanicle solution.
1, Compared old and new values in Z offset on tool 1.
2, Loosen the coupling between ball screw and servo.
3, Used a dail indicator and turned the ballscrew to get the new value same as old.
