Possible to see cycle time in Mazatrol T2
Likes Likes:  0
Results 1 to 4 of 4
    Aug 2016
    SWEDEN
    35
    Default Possible to see cycle time in Mazatrol T2
    Hi,
    Is it possible to see the cutting time for a part when the machine is running and you for example change some speed and feeds and using the vtc button to transfer it into the program. So you can see the diffrence, or is it only possible in the graphic simulation after you have waited for the simulation to be done, which is kinda pain in the ass?
    Never checked but how accurate are those simulation cutting times?
    Feb 2007
    Joplin, MO
    369
    85
    17
    I believe it is on the trace page. If I remember correctly it is the third menu button from the left. Time is in the lower right quadrant.
    Feb 2010
    Washington State
    422
    577
    153
    Quote Originally Posted by panscan View Post
    Hi,
    It is displayed after running each part on the "Trace" display.
    So go to Program, make your changes, then softkey over to "Trace".
    You will get a graphic, similar to the simulation display but it's a live graphic during the cut.
    Go to Auto mode, softkey to "Trace" and press the "Workpiece Figure" and "Shape" softkeys.
    Press the cycle start button and you'll be cutting with live graphics.
    On the bottom right of that "Trace" screen, cut time is displayed. If you pause the program, the timer will pause.
    I always run new programs from that "Trace" screen.
    Feb 2015
    SWEDEN
    620
    107
    294
    If you simulate you can find the time under layout, bu you have to run a full simulation first
