Problems Threading on Mazatrol T32-2
Results 1 to 15 of 15
    May 2013
    Perrysburg, OH
    30
    Default Problems Threading on Mazatrol T32-2
    Hoping you brilliant minds can help me, yet again, with a threading issue. The finish product is an auger, so it's super deep with a high pitch. The problem I'm having is that the wall seems to be "trailing" away from the spindle.
    Take a look:
    Here's the beginning of a part that I scrapped using the same settings (but a wider tool tip):
    Can anyone explain why things seem to have magically changed? I'm at a total loss and Mazatrol is, as usual, not helping. Thank you!!
    EDIT: PROGRAM PARAMETERS:
    PNo. MODE # CHAMF LEAD ANG MULTI HGT NUMBER V DEPTH TOOL
    2 THR OUT [1] 0 0.79 89 1 0.55 65 0.005 11
    SEQ SPT-X SPT-Z FPT-X FPT-Z
    1 1.89 0. 1.89 13.25
    Apr 2016
    Tennessee
    133
    110
    17
    What is the diameter, length, sfm and number of passes?
    Jul 2006
    Arizona
    4,641
    18517
    4423
    Quote Originally Posted by cleroux View Post
    The thread angle needs to be set to zero (0) on the Mazatrol threading cycle in order to cut square threads.
  4. Likes toolsteel, kevin66, xa-mont liked this post
    May 2013
    Perrysburg, OH
    30
    Quote Originally Posted by edge22 View Post
    Just edited the original post. Sorry!
    May 2013
    Perrysburg, OH
    30
    Quote Originally Posted by Philabuster View Post
    I did this. Ran a few trials on the original part and it still appears to be doing the same thing. Could I have something else wrong?
    Jun 2013
    Oregon
    1,554
    551
    930
    I dont understand what you mean by trailing
    Jul 2006
    Arizona
    4,641
    18517
    4423
    Just to be clear we are talking about the same field, I'm talking about making ANG 0 instead of 89.
    You also need to make sure the part is not being pushed back into the chuck as the part is being threaded. That may be the case if you do not have a positive stop.
  9. #8
    May 2013
    Perrysburg, OH
    30
    Yeah, that's what I changed. Then I ran a few passes and it seems to be doing the same thing. (I am still running on the part in the first picture, so maybe I'm seeing things, but I used blue to see.... ). I checked my zero to the edge of the part and I'm not pushing more than maybe 3 or 4 thou. My angled wall is off by about .080". I'll keep messing with it, but I'm running low on creative corrections.
  10. #9
    Jul 2006
    Arizona
    4,641
    18517
    4423
    On rare occasions, I've seen Mazatrol do funny stuff when you edit the process. Worst case, try erasing the process and re-doing it with the same values, but put in ANG 0 from the start.
    The only other thing I can think of is the tool data is wrong.
  11. Likes Red James liked this post
  12. #10
    May 2013
    Perrysburg, OH
    30
    Early indications are that this fixed it. I ran on my already scrapped part and it looks pretty straight. I'll update once I get a new part cut. Thank you for all the help!
  13. #11
    Apr 2013
    South Australia
    437
    117
    148
    Yes I get that often if I have been doing a lot of editing in a program. I only try it a couple of times then just rewrite that unit and 9 times out of 10 it fixes the problem
  14. #12
    May 2013
    Perrysburg, OH
    30
    Bad News....
    Quick question though. Could changing the RPM override during the cycle do this? I had some gnarly chatter and adjusted it instinctively. So, as Steve Urkel would say... "Did I do that?"
  15. #13
    Apr 2015
    159
    172
    87
    Bad News....
    Dont do that. Pretty sure our Tplus lathes will allow you to change spindle speed while threading but Ive never tried to prove it as I would be guaranteed a scrap thread.
  16. #14
    Jul 2006
    Arizona
    4,641
    18517
    4423
    Bad News....
    YES!
    The older controls will loose the thread lead if you the override the speed. Also, do not change the programmed speed once you start the cut. Only change the speed in between parts. Never change the speed once you cut your first pass. I scrapped an expensive part learning that lesson.
  17. Likes cnctoolcat liked this post
  18. #15
    Apr 2014
    AUSTRALIA
    604
    230
    148
    YES!
    who hasn't been there :P
