QT-6T Mazatrol T+ Plus Barfeeder, PLC, Parameters, Floppy - Help
Likes Likes:  0
Results 1 to 18 of 18
    Apr 2021
    SLOVENIA
    8
    Default QT-6T Mazatrol T+ Plus Barfeeder, PLC, Parameters, Floppy - Help
    Hello.
    There are several problems, in this thread there are questions and solutions.
    Everything in order
    Problem number 1:
    Mazak QT-6T Mazatrol T + (plus) machine worked with a barfeeder.
    Now I turned on the machine without a bar feeder and an error appeared on the display: 33 EMERGENCY STOP.
    It is not possible to reset the error, the machine does not respond.
    The EMERGENCY STOP button and limit switches are working properly.
    Maybe you need to fix something in the PLC?
    please any help ...
    Jun 2013
    Oregon
    1,782
    644
    1099
    You may have more than one alarm. Look at you "DIAGNOSE" page. This will show if you have more than one alarm.
    Apr 2021
    SLOVENIA
    8
    Quote Originally Posted by Gobo View Post
    Only 33 EMERGENCY STOP.
    What do these readings mean? (operating time):
    Power ON -
    Auto CUT -
    Auto OPR -
    Total CUT -
    May 2009
    The Woodlands, Tx
    602
    77
    91
    it is the missing estop button that was on the bar feeder. did you change parameters to tell machine to not look for the bar feeder? you may need to add jumper on board where the missing estop plugged in
    Justin
    Apr 2021
    SLOVENIA
    8
    Quote Originally Posted by Justin_Terry View Post
    Justin
    I'm new to Mazak.
    I don’t know where to change the settings so the machine doesn’t look for the bar feeder.
    That's why I'm here to help me)
    Jun 2013
    Oregon
    1,782
    644
    1099
    Do you have any machine manuals for it?
    Apr 2021
    SLOVENIA
    8
    I have only:
    - parameter list
    - operating manual.
    I need for Mazatrol T plus
    - electrical circuit
    - how to disable polling of the bar feeder from the PLC?
    I want to remove the extra wires, relays and starters that were used for the bar feeder.
    But first, I need to start the machine.
    Any help is appreciated.
    Apr 2021
    SLOVENIA
    8
    I look forward to your help.)
    problem number 2:
    Why is there only Mazatrol when creating a new program?
    the option specifies EIA/ISO
    does it need to be activated in the parameters?
    sorry i'm new to mazak
    May 2009
    The Woodlands, Tx
    602
    77
    91
    you have none of those options. and you dont need to remove anything off of machine to disable bar feeder, just change parameters and possibly add a jumper to complete e stop circuit.
    Jun 2013
    Oregon
    1,782
    644
    1099
    correct. If the option is highlighted, it is active.
  11. #11
    Jun 2013
    Oregon
    1,782
    644
    1099
    Quote Originally Posted by gerka View Post
    I have only:
    - parameter list
    - operating manual.
    I am pretty sure that a parameter change is needed to disable the barfeeder. Have you looked through the parameter list ?
  12. #12
    Apr 2021
    SLOVENIA
    8
    thank you for your help. I rang the bar feeder connector pins and found where to put the jumper for error 33.
    now there are other alarms that I am solving.
    help me activate EIA / ISO
  13. #13
    Nov 2012
    Wisconsin
    110
    281
    14
    I'm new to Mazak.
    press the "machine" button.
    then "option" soft key.
    make sure "barfeed" is not highlighted.
  14. #14
    Apr 2021
    SLOVENIA
    8
    Thanks for your answers and help.
    I solved an error 33, jumper, but I had other errors.
    Now in search of their decision.
    What do you think I can't write a new program in EIA / ISO (G-Code)
    Any ideas?
  15. #15
    May 2009
    The Woodlands, Tx
    602
    77
    91
    no eia without the option you will have to call mazak and buy the option.
    look for parameter that sets if the chuck is looking for confirmation sensors or just on timer. it is currently set to sensors, that is why you are getting alarms.
  16. #16
    Apr 2021
    SLOVENIA
    8
    are you sure the EIA / ISO is not?
    in the list of options number 2.
  17. #17
    May 2009
    The Woodlands, Tx
    602
    77
    91
    100% the option page you posted does not have eia.
  18. #18
    Jun 2013
    Oregon
    1,782
    644
    1099
    Yes for sure, No EIA
