QT10 turret end cap removal
Likes Likes:  0
Results 1 to 2 of 2
    Sep 2012
    California, Ventura county
    1,839
    635
    778
    Default QT10 turret end cap removal
    Simple question are there any surprises to
    removing the end cover on a QT10 turret
    I'm replacing the way cover wipers and such
    problem is the PO ran a bunch of stainless with the
    chips caught between the wiper and actually wore a large dip in the
    surface.
    bad enough that it probably wont seal very well.
    there appears to be 7 bolts holding the thing on.
    is it any more complicated then remove the bolts and pull it off,
    and the reverse to re install it?
    see photo for more clarity that's the part I'm referring to
    Feb 2015
    SWEDEN
    632
    107
    301
    You can just remove it and reinstall it.
    Only surprise you get is how clean it will be on the inside
