Hello,
I have to set my turret in the axis. The clocks sensor shows ~ 0.25mm out of position. I don't know how to go about it. Do it with the hydraulics on? Loosen the screws marked in the picture and set?
It could be that the pin is still in the turret and bent.
This pin is normaly removed when adjusting this at the first time after a crash.
The 8 bolts are marked with red
The pin is marked with green
The cap hiding the pin is marked with blue
I think you need a slide hammer to get the taper pin out.
Edit: It looks like your turret have or had 2 pins.
It looks like you were right. I managed to remove one, while I have a bit of a problem with the other. Should I insert them again after setting the turret?
