QT15N Turret positioning
Yatarra
Oct 2, 2019
Hello,
I have to set my turret in the axis. The clocks sensor shows ~ 0.25mm out of position. I don't know how to go about it. Do it with the hydraulics on? Loosen the screws marked in the picture and set?
I did as you suggested benganboll, but I can't set it to zero. In the opposite direction I can move around 0.15 ~ 0.2
It could be that the pin is still in the turret and bent.
This pin is normaly removed when adjusting this at the first time after a crash.
The 8 bolts are marked with red
The pin is marked with green
The cap hiding the pin is marked with blue
I think you need a slide hammer to get the taper pin out.
Edit: It looks like your turret have or had 2 pins.
It looks like you were right. I managed to remove one, while I have a bit of a problem with the other. Should I insert them again after setting the turret?
