Relief Groove
Likes Likes:  0
Results 1 to 5 of 5
Thread: Relief Groove
    Nov 2015
    Washington
    90
    7
    Default Relief Groove
    QT10-N, T-Plus Control
    I have a 1 1/2 x 8 internal thread. I've been using a boring bar (93 / 35) to put the relief groove on the inside. It's working fine but the problem I'm having is it's packing up with chips before the finish pass. And what I would like to do is have it retract and stop before the finish pass so I can pull the chips out.
    May 2018
    New York
    155
    116
    82
    I'm no master, but I think I would copy the PNO and leave the FT number from the first instance blank and the RT from the second instance blank, then insert a M0 in between the ops.
    Edit: just tested on my T-2, if you place a M0 on the end of the SEQ block, it will stop before the finish pass.
    Dec 2018
    163
    413
    50
    Change the numbers to leave a little bit of material for finish and add a manual process.
    Nov 2015
    Washington
    90
    7
    The problem with the first option is I need it to retract out of the bore. And as for a manual process I have to admit I don't know how to do that in a program. I don't have a lot of experience with the lathe. I've made a lot of parts but when I have problems I start to struggle. That's why I rely on and appreciate every ones input.
    Dec 2018
    163
    413
    50
    If I have time tomorrow I'll look at the programming manual how to do a manual process. I haven't run the DT20 with T-Plus in a while so I can't remember off the top of my head.
