Tried doing it with the cutoff but it was too hard to detect when an insert would fail. You'd probably have more luck with an insert drill as its significantly more load, but it would definitely be trial and error as to what percentage you'd want the machine to alarm at. I wouldn't be too concerned with an insert drill stopping in the middle of the cut. It should be able to take that little bit of abuse no problem. You will just want to monitor z-axis load when you're cutting to see what it is during normal cutting, and what it is during worn insert cutting. The problem is any type of load spiking, which could cause a false alarm. You might get a spike from material fluctuation, or just any weird machine anomaly. There are certain overload tables you'll need to write at the beginning of the feed you want to monitor. Each axis has a writable field, but I'm not sure what they would be on your particular machine. Just ask your local Mazak application engineer or tech center, or pull out your 50000 page manual and start reading...
Possibly a simpler solution would be to give the tool a tool life in tool data? You can either count number of minutes in cut or number of cuts. The machine will soft alarm once it hits either minutes or number of uses depending on the user parameters. Again, user parameters are a little machine dependent so refer to your manual or ask your local Mazak dude.
E
