SQT-10M Spindle Start-up
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2015
    Washington
    90
    7
    Default SQT-10M Spindle Start-up
    SQT-10M T-Plus
    Can anyone tell me which parameter I need to change for the spindle accel time.
    I need to reduce the startup load a little. Mazak wasn't quite sure and Mitsubishi told me SP19 but he didn't sound really confident about that. So I was hoping someone could verify the right parameter to change. Mine right now is set to 30.
    Thanks!
    Feb 2010
    South Jersey
    42
    5
    9
    On my SQT-18MS T32-3, SP19 is the correct parameter.
    My factory setting was 300, it is now set to 500.
    Hope that helps!
    Nov 2015
    Washington
    90
    7
    I finally found someone at Mitsubishi that knew for sure it was SP19. The T32-3 might be a bit different than the T-Plus because mine was set at 30 and they said that was factory. But after trying different settings I ended up at 250 which I'll see how that works out. Thanks for confirming that was the right parameter.
