chad883
Cast Iron
- Jan 12, 2012
- indiana, usa
Hi all I hope someone can help. My problem is that the milling shaft on a SQT 200MY is not engaging and disengaging properly. Both prox swithes are working fine. It started off just being the disengage had a problem. I removed the middle cover on face of turret, removed prox swithes, still on monting bracket, cleaned them and flushed the drive unit with oil as best I could. Then replaced swithes and ran. Seemed to work for a bit, but back to same problem. The air supply is set properly and the shaft moves pretty easily back into place when I have had to help it retract after an alarm. Thanks for any info and guidance.
