SQT15MS T-Plus Mill line not straight
Results 1 to 7 of 7
    Oct 2014
    CANADA
    British Columbia
    1,063
    1092
    606
    Default SQT15MS T-Plus Mill line not straight
    Hi All,
    Tried milling a hex on this thing for the first time.
    Although the book says that it should auto comp for the cutter diameter, I had to offset my ½" endmill by ¼" to get the correct size.
    Using a LFT Face option. I have an STP for the first line, and after that all lines for a FPT-R and an angle.
    For some reason the flats on the hex aren't a straight line, but are rounded
    Anyone experience this before?
    Thanks!
    Nov 2016
    POLAND
    30
    Did you type in, in tool data, tool diameter?
    Sent from my D5803 using Tapatalk
  3. Likes ManualEd liked this post
    Oct 2014
    CANADA
    British Columbia
    1,063
    1092
    606
    Quote Originally Posted by tspiszak View Post
    Yup, I uploaded a few photos of the program and tool datas.
    I've tried removing the ¼" cutter comp, but still the same radius of a hex.
    It's got me stumped for sure.
    Jul 2006
    Arizona
    4,701
    18659
    4546
    Quote Originally Posted by ManualEd View Post
    How did you set X geometry for the endmill? That is usually the problem.
    Oct 2014
    CANADA
    British Columbia
    1,063
    1092
    606
    Quote Originally Posted by Philabuster View Post
    At first I had it set from the center line offset I have scribed on the live tool unit.
    That made my hex ¼" smaller than it should be. I tried a +.25" offset for wear, which didn't help.
    Tried subtracting ½" from the actual tool offset number, which didn't help.
    The only thing I didn't try was milling a .25" larger hex to comp for the problem.
    Would programing by XY coordinates instead of degrees help with anything?
    Thanks for the replies!
  7. Likes Philabuster liked this post
  8. #6
    Jul 2006
    Arizona
    4,701
    18659
    4546
    You need to set the endmill the same as you would set a drill. X0 is centerline of the endmill. You set it correctly the first time.
    Also, I think you are programming it incorrectly. What size hex are you trying to make? You need to program to the corners of the hex and not the flats.
    Your program with .87" on the hex will make a hex with a distance across the flats at 1.507". If you are trying to program a hex of 1.74" across the flats, you need to change your program to 1.004" on each line.
  9. #7
    Oct 2014
    CANADA
    British Columbia
    1,063
    1092
    606
    Oh FFS.
    When I looked at this sample program in the manual, I thought it was 70mm across the flats of the hex, but its 70mm across the CORNERS. I feel like a putz.
    When I let it run the first time and it milled a tiny hex, it looked pretty good to me.
    I think this should solve the problem.
    Thanks a lot Phil!
  10. Likes Philabuster liked this post
