Hi Guys,
I Replaced the power supply (SF-PW) on this spindle drive about 3 months ago and it was working fine for the last 3 months. For the last 2 days the machine would just stop in mid cycle with a spindle controller error on screen. I powered off and back on and it worked for a while. then it stopped working completely.
The spindle drive LED's are all off . On closer inspection I un-plugged the 3 black therminals from the right side on the back of SF-CA Card. Powered up and all LED's working. I plugged back in the Terminal strips one at a time and it's only when the top one is in that the LED's go out. So the top Therminal strip is pulling the drive down. what can I do ? Should I try and trace where the wires from this strip are going, should I check or look for anything in particular ? The power supply LED goes down with the Card LED's too.
