Main spindle and live tooling at same time SQT250MY -640T
Likes Likes:  0
Results 1 to 16 of 16
    Nov 2010
    Leicester, New York, USA
    11
    Default Main spindle and live tooling at same time SQT250MY -640T
    Is there anyway to run the main spindle and the live tool at the same time on a Mazak SQT250MY with a 640T control? I want to run a sanding wheel/brush in the live tool holder along the turning as the main spindle rotates. Not sure if it's possible to spin both at the same time, and if it is, how? Thanks.
    Apr 2013
    uk
    46
    Have been told this was not possible, I was looking to use a drill in a milling holder and reverse the spindle to create more speed but wasn't possible.
    Mar 2011
    NY USA
    841
    178
    561
    I would think it would be possible, just have to make sure you are pulling rpm from the correct encoders to drive your IPR feed rates. Then again I am a FANUC guy not a mazak guy.
    Feb 2008
    Ireland
    247
    176
    50
    The only time I've had them both going together is when polygon machining.
    That would work for you if you have that option.
    If you go to your options page and see if "Polygon Machining" is black or white. If it's black you have it.
    Mar 2007
    ct
    544
    114
    66
    Yes.
    Program rpm on spindle and then rpm on live and keep going
    Fanuc m3 s1000 p1
    M4 s2000 p2
    Ussually spindles are programed with different codes
    Dec 2010
    PA
    650
    185
    170
    My SQT18MY will do it so your 250MY should as well. I didn't catch if you used eia or mazatrol. We use mazatrol for everything and I have run a live tool and the main spindle using a manual program (MNP)
    Sep 2006
    Atlanta, GA
    3,054
    445
    948
    If you can mill a hex then I don't see why not, don't know if you can feed in Z at the same time as well if that is what your trying to accomplish.
    Nov 2012
    Wisconsin
    2,108
    3458
    2649
    there must be an option similar to M90 in Moris....M90 drills while turning main spindle and toolholder
    Dec 2010
    PA
    650
    185
    170
    You can do it with LCT (line center)
    Assuming a 2" od, and a brush in a horizontal holder, make your cut point x2 z 0 or something like that, give your wire brush a sfm, describe the tool as a 3" endmill (or whatever diameter the brush is)
    The way to make it feed is actually to use the main spindle in c axis mode. You'll have to start at x2, z0, c0 and feed to z.5, c180 (for example), then z1., c360, then z1.5 c 540 etc to make the main rotate as the brush feeds along. You can control ultimate feed rate by putting in some ridiculous feed per rev number in for the brush in the LCT process.
    Feb 2008
    Ireland
    247
    176
    50
    Quote Originally Posted by SMT View Post
    That's using the C-axis.
    That's not what he wants as far as I can see.
    He wants to spin the main spindle at 2000 RPMs and Spin the live tool at 2000 RPMs
    Both at the same time.
  11. #11
    Dec 2010
    PA
    650
    185
    170
    Quote Originally Posted by mbpp View Post
    I don't think 2000 rpm on the main would fly using LCT. I don't think you could give it a big enough feed rate to get that and have it stop on the programmed point...
    I think i'd use MNP then. You can pretty much do whatever you want then. Except I think it may force you to pick between rpm on the main or rpm on the live tool and a c axis main.
    EIA may be the only way.
  12. #12
    Feb 2012
    Oklahoma
    11
    maybe program it in the mmp or mnp we did that to sand or polish some parts on our 250msy 640t.
  13. #13
    Jun 2018
    Illinois
    Quote Originally Posted by Dbwebb View Post
    We are trying to do the same thing?
    Did you get it to work? G-code example?
  14. #14
    Aug 2011
    Austin, Texas
    7
    I wanted to do the same thing-Using a rotating tool in Lathe mode. After research with Mazak was told I had to purchase "Gear Hob" option. $1500. it now works.
    Brett......
  15. #15
    Dec 2008
    Bethlehem Pa USA
    74
    27
    17
    Its called grinding mode. Here is a sample EIA program that we just ran. We used a saw to part off plastic parts. This works on QT250-II Nexus. And also on QT250 smooth
    <MILLTURN>()
    G97 G28 U0.0
    M205M5
    T0500
    M48
    M200
    G97M203S20
    M610
    G97M203S2500
    M4S1000
    G0X.7Z-.306
    G1X-.015F15.
    G0X2.
    G28U0.
    M05 M205
    M612
    G4X.5
    M49
    #125=#125+1
    M99
    for some reason.. while in grinding mode.. my machine didn't wait for the live tool to fully engage before spinning up..Mazak couldn't help me on that issue... so that is why i have the M203S20 line in there..
  16. #16
    Nov 2016
    POLAND
    26
    What's m610 and m610? Sqt250 doesn't have them.
    Sent from my D5803 using Tapatalk
