I am still learning the ins and outs of the TPlus control on my lathe. Right now I have a simple mazatrol program that is doing an outside bar operation. It is machined down from 2.0" stock to 1.50" diameter with 0.025" depth of cut. My question is with regards to the POSITION display onscreen. If I have to make a wear offset adjustment in the X dimension lets say +0.005" the readout as it is cutting shows the X POSITION at 1.505" even though I am cutting at 1.500" with the corrected wear offset. Is there a way to not have the control include the offset number in the POSITION display and only show the COMMANDED position of 1.500" with the control handling whatever wear offset is asked of it. On my Fanuc if I add a wear offset to a tool the COMMANDED position will still show as 1.500". Wondering if this just standard with this type of mazak tplus control or if there is a parameter to not display the offset position relative to the commanded cut position.
