T-Plus Helical Interpolation
tzak
Jun 10, 2016
Does anyone know if it's possible to do a helical interpolation in G-code on a T-plus controller? Lathe is a SQT MSY.
I tried some test code but I get an "919 Illegal g16-19 command" error. Not sure if it's my code or if the controller just can't handle it.
It is an option on that controller.. go to the options page on the controller and see if it has tornado milling enabled
If not and you have cam software you can output the almost the same thing using linearise arcs which will output g01
I checked on the controller seems like "circular interpolation" is not enabled. Is there a way to turn it on?
