T Plus Indefinite Dwell?
Likes Likes:  0
Results 1 to 10 of 10
    Aug 2010
    Illinois
    66
    15
    10
    Default T Plus Indefinite Dwell?
    I have some parts with external threads that I have to manually clean up with sandpaper before parting off. What I do now is a manual G4 dwell process, sending the turret home, shut off coolant and run the spindle at 2000 rpm for 5 seconds. This 5 seconds gives me time to feed hold, so I can go in there and take as much time as I need on the threads. When I'm done, I hit cycle start and the 5 second dwell runs down and the program completes. This works fine if I'm there paying attention. If I'm doing something else at the time, I blow the opportunity to clean up the threads. Is there any way to dwell this manual process indefinitely, so it just sits there until I hit the cycle start again? Thanks!
    Sep 2014
    Georgia
    867
    9
    205
    Optional stop. But you have to remember to turn that on the control every time you start the machine. Or you could just do an m0
    Iím assuming you want to do this in mazatrol just do an mcode block and pop that m1 in there
    Aug 2010
    Illinois
    66
    15
    10
    Quote Originally Posted by Ianagos View Post
    Won't that stop the spindle?
    Sep 2014
    Georgia
    867
    9
    205
    Ah I missed that part. Iím not sure if it will stop the spindle.
    May 2007
    Massachusetts
    916
    14
    94
    I might put in a do/while loop that dwells until something else happens. Pick an unused offset, set at zero, and when you're done, change it to a one. do while (offset number) is less than .1, When you change the offset to one, it will continue. Something like that, anyways. I've never done that, but only imagine it might work...
    Jun 2013
    Oregon
    1,750
    624
    1078
    Ah I missed that part. I’m not sure if it will stop the spindle.
    It will definitely stop the spindle.
    Sep 2014
    Georgia
    867
    9
    205
    Quote Originally Posted by Gobo View Post
    Is there a parameter that will keep the spindle on?
    I thought the feed hold would actually cut the spindle off aswell. Iím pretty sure it did on my sqt with a tplus
    Edit:
    I may be wrong my memory is fuzzy. I just remember I had a job where I had to polish in the middle but I think I just did an m1 and then would manual start the spindle then go back to auto and hit start
    Jun 2013
    Oregon
    1,750
    624
    1078
    The only way I can see to do it is to use an M0 (program stop),then when it executes the program stoop, go to manual mode, start the spindle and do tour sanding, stop the spindle then go back to auto and cycle start. The program will pick up from the program stop and continue. That should involve four button pushes.
    Aug 2010
    Illinois
    66
    15
    10
    Looks like what I'm doing now is most efficient. Just have to pay more attention to not miss the 5 second window. Thanks for the suggestions.
    Sep 2006
    Abingdon, VA
    3,648
    4904
    3588
    I've rigged up sandpaper and Scotchbrite on tool stations, and let the machine do the polishing.
    Need a quick way to shift/adjust for fresh abrasive, do it every ? parts as required.
    ToolCat
