T32-B control rebuild and Z axiz will not move
Results 1 to 3 of 3
    Oct 2019
    Indiana
    Default T32-B control rebuild and Z axis will not move
    Hello, all. I have an old QT 15 N with a T32 B control. The control died, so I sent it to Mitsu for rebuild. I got it back, and after I installed it the machine fired right up and I was happy. Well, until I saw that their parameters weren't even close to what I had. No big deal, because I have digital and hard copy back ups. So, after about 20 minutes of keying in my old, known, and proven parameters I thought I'd be back in business. Nope. I got everything to work except the Z axis. It won't home, jog, rapid, or move with the hand wheel in Z. The 12 place turret indexes correctly, the spindle ramps up nicely, the tailstock slides well. I had to change parameter A9 on the X axis to 99999 to get it to go home. Piece of cake. But the Z axis will not move. At all. When I move the hand wheel for the Z axis, the numbers on the display indicate movement FOR LESS THAN A SECOND, then the display goes back to the original number (which is always a 1.0). I had to put a dial indicator on the turret to make sure it wasn't creeping on me. So...after a control repair on a great running machine, I re-installed my parameters, and the Z axis won't move at all. Oh, and there are no alarms. I triple checked my parameters, paying close attention to the "A" parameters. What did I miss? I'm wanting to think that this is some sort of a parameter input error on my part. Is there something in privileged mode that I need to change? After 3 hours of trying to find the problem, I'm at a loss. I would sure appreciate it if one of you Mazak gurus could point me in a better direction. Thank you.
    Oct 2019
    Indiana
    Update
    Problem solved. I verified that all the parameters I manually input were correct and I re-checked all the cable bundles to the control. I figured I'd try to reload from the EEPROM before I wiped the memory with a re-initialization. It worked. The parameters last saved to EEPROM were loaded and now the Z axis works as expected. I still don't know what the error was. But a parameter reload did fix it.
  3. Likes cnctoolcat, Philabuster liked this post
    Apr 2013
    South Australia
    437
    117
    148
    Maybe go through the parameters you have with what the EEprom loaded and make the changes to your hard copy for the future
