Tony Valentine
- Oct 28, 2019
- Lebanon, Missouri USA
The machine being used is a Mazak Nexus 10800-II
It uses Mazatrol Matrix
I am programming a part that needs a tapered hole in it. I need to rough out the hole before using a tapered endmill to finish it. Is it possible to circle mill using the tornado option at a taper?
example:
It will be a thru hole that is 90 mm deep. The finish size will be 50 mm on one end with a 7 degree taper, and the back side will end up being about 27.9 mm. I would like to drill a 27 mm hole, and then rough it out to a mm oversized.
Thanks for any input- Tony
example:
