Tapered Tornado Interpolation
Likes Likes:  0
Results 1 to 8 of 8
    Oct 2019
    Missouri
    Default Tapered Tornado Interpolation
    The machine being used is a Mazak Nexus 10800-II
    It uses Mazatrol Matrix
    I am programming a part that needs a tapered hole in it. I need to rough out the hole before using a tapered endmill to finish it. Is it possible to circle mill using the tornado option at a taper?
    example:
    It will be a thru hole that is 90 mm deep. The finish size will be 50 mm on one end with a 7 degree taper, and the back side will end up being about 27.9 mm. I would like to drill a 27 mm hole, and then rough it out to a mm oversized.
    Thanks for any input- Tony
    Oct 2019
    Missouri
    I'm not sure why it says "plastic" under my name. The hole will be machined in 1035 CD steel.
    Langley, B.C.
    1,687
    341
    985
    Quote Originally Posted by Tony Valentine View Post
    ...I'm not sure why it says "plastic" under my name...
    Because you're a newbie. As your post count goes up your status changes...
    Jun 2013
    Oregon
    1,542
    542
    926
    I dont believe that cycle allows for a tapered hole.
    Sep 2019
    I've done it before, but it was a 45° taper. It took quite a bit of time for it though. probably easier to do it with a manual program over a circle mill unit. I run 640, haven't got to mess with the machines with matrix yet. I assume there are quite a few things that are a pain on 640 that are easier on matrix. sorry this doesn't help much, but I'm sure it can be done, there is probably just an easier way.
    Jun 2013
    Oregon
    1,542
    542
    926
    I am interested in what your cycle looked like. Can you post a pic?
    Oct 2019
    Missouri
    Due to an error way above my paygrade, I will not have to machine they part after all. We were never awarded the bid on the part in the first place.
    Jan 2013
    Plainfield, Indiana, USA
    1,739
    1313
    926
    If someone else has this problem, it can be machined with the "Spiral" machining option. Have to write a manual program to use it as it is an EIA option, but it does work just fine.
