Results 1 to 8 of 8
Thread: Tapered Tornado Interpolation
10-28-2019, 02:25 PM #1
The machine being used is a Mazak Nexus 10800-II
It uses Mazatrol Matrix
I am programming a part that needs a tapered hole in it. I need to rough out the hole before using a tapered endmill to finish it. Is it possible to circle mill using the tornado option at a taper?
example:
It will be a thru hole that is 90 mm deep. The finish size will be 50 mm on one end with a 7 degree taper, and the back side will end up being about 27.9 mm. I would like to drill a 27 mm hole, and then rough it out to a mm oversized.
Thanks for any input- Tony
10-28-2019, 02:29 PM #2
I'm not sure why it says "plastic" under my name. The hole will be machined in 1035 CD steel.
10-28-2019, 02:32 PM #3
10-28-2019, 02:39 PM #4
I dont believe that cycle allows for a tapered hole.
10-30-2019, 10:38 AM #5
I've done it before, but it was a 45° taper. It took quite a bit of time for it though. probably easier to do it with a manual program over a circle mill unit. I run 640, haven't got to mess with the machines with matrix yet. I assume there are quite a few things that are a pain on 640 that are easier on matrix. sorry this doesn't help much, but I'm sure it can be done, there is probably just an easier way.
10-31-2019, 06:02 PM #6
I am interested in what your cycle looked like. Can you post a pic?
11-08-2019, 01:08 PM #7
Due to an error way above my paygrade, I will not have to machine they part after all. We were never awarded the bid on the part in the first place.
11-08-2019, 08:22 PM #8
If someone else has this problem, it can be machined with the "Spiral" machining option. Have to write a manual program to use it as it is an EIA option, but it does work just fine.
