Very first line of a Mazatrol program: use the "offset" feature. One program, repeated as many times as you enter an X, Y offset, which can be thought of as the distance between 'zero' of your layout. Play with it a bit and it's obvious.
The "offset" is the distance from a point on your first shape to the same point on the next shape . . . X, Y distance, either plus or minus. Program a 1/4" drilled hole with center at 0,0 and in the first line choose multiple, offset type. Insert a line. Use .75 for the X offset that appeared when you inserted a line, and 1 for the Y offset. Now do a tool path. Two holes will show on the tool path even though you only programed one. Play with it a little and you will see how easy and powerful it is. Even works with negative offset values.
Notice
