Is there a way pattern a program in Mazatrol (M32 or M+)
Likes Likes:  0
Results 1 to 9 of 9
    Dec 2017
    Michigan
    57
    Default Is there a way pattern a program in Mazatrol (M32 or M+)
    Basically I have a program for one part but am now going to be make a 42 parts at once out of a large sheet. Is there a way that I can just pattern the same program across the sheet?
    Apr 2013
    South Australia
    446
    120
    148
    You can just move your WPC and copy the program 42 times. Maybe use the multi part and move the WPC and copy 9 times with a program change to 2 on the last to get the exact amount of parts you need. There may be other easier ways but I don't know them
    Jan 2013
    Plainfield, Indiana, USA
    1,822
    1405
    967
    Very first line of a Mazatrol program: use the "offset" feature. One program, repeated as many times as you enter an X, Y offset, which can be thought of as the distance between 'zero' of your layout. Play with it a bit and it's obvious.
    Dec 2017
    Michigan
    57
    I am not familiar with multi part, what is it, where is it and how do you use it?
    Dec 2017
    Michigan
    57
    Quote Originally Posted by Red James View Post
    Not sure that I am tracking with you. I often have an offset line right below my WPC but am not sure how to use it to repeat the program. Are you suggesting that I run the program once, then adjust the offset, run again, and continue adjusting the offset and running until all of the parts are complete? I am trying to run this all night lights out
    Dec 2017
    Michigan
    57
    I had always assumed that the argument characters that show up in the sub program option could be used to pattern a sub program, but could never figure out how to use it.
    Apr 2013
    South Australia
    446
    120
    148
    Multi is in the first line of your program
    Jan 2013
    1,822
    1405
    967
    The "offset" is the distance from a point on your first shape to the same point on the next shape . . . X, Y distance, either plus or minus. Program a 1/4" drilled hole with center at 0,0 and in the first line choose multiple, offset type. Insert a line. Use .75 for the X offset that appeared when you inserted a line, and 1 for the Y offset. Now do a tool path. Two holes will show on the tool path even though you only programed one. Play with it a little and you will see how easy and powerful it is. Even works with negative offset values.
    Dec 2017
    Michigan
    57
    Alright I got it now, between James and Sudsey, Thanks guys. I was getting confused with the offset that you were describing within multimode and just a regular offset feature. This is super handy, wished that I would have known a long time ago how to do this.
