benganboll
Hot Rolled
- Feb 23, 2015
- Sweden Östersund
My C axis servo Driver TRA 8A-L gave up yesterday on my QT10ATC T3 -87.
The boards has a OVC alarm (Over current I guess) and the load meter says constant 220-240%.
After a few restarts and the board operates as it should for a while (Loadmeter back to normal).
I tried to switch main board with XZ driver and the problem moves over to X axis so problem is isolated to the main board.
I will try to change all electrolytic capacitors on the board since thats the only components that actually goes bad by aging 32 years.
Anyone else have any luck with this by just changing the electrolytic capacitors?
I have repaired 2 spindle controllers (FR-SE) one of them by only replacing the electrolytic capacitors and one of them required new DK434 and power transistors.
Next step is to change the DKxxx but I dont have the time to wait for them
