rockfish
Titanium
- Aug 27, 2006
- Munith, Michigan
I am currently running a 500 piece order of gear blanks. I have a .625-.626 bore that needs to be held. I am drilling the hole with a .578 drill, then boring with a 3/8 boring bar with CMMT insert (not sure if that's right.......... it's the little 80* diamond insert, positive rake). Anyway, I've got this set up using that 3/8 boring bar to rough the bore to within .015 of size, then I come in with another 3/8 solid carbide boring bar with the same insert for finishing. Throughout the day, I am constantly changing offsets on this job, as the bore keeps getting smaller and smaller. How much changes in size would be considered normal ??? I'm shifting my offsets up to .002 to .0025 from my starting point in an 8 hour day. That seems excessive to me, and I can't figure it out. I thought I was having trouble before, because I was just using one boring bar to rough and finish, but now I'm using two and the finishing bar is taking very little stock out and should not be wearing out.
Frank
Frank
