Hopefully someone can help me out.
I have a regular job that involves removing a large amount of Inconel 625 Cladding on an OD which also has a large intermittent cut going over a cross hole.
Up till now we have been using forward approach CNMG`s to get through this which is costly in both time and inserts.
I spoke with my Sandvik Rep and he recommended changing our process to turn milling using a ceramic button tipped facemill, He showed me a video of a recent trial that he had done elsewhere on what was basically the same job and it was most impressive and a huge reduction in time (will save hrs potentially).
I have tooling and inserts now in place for the trial though unfortunately the Mazatrol Turn Milling cycle will not work as is recommended (It will not feed in on Y axis) and based on other reports from various forums I believe the only way round this is to write a manual program. This is where I am now lost in a sea of G codes ( I am fine with regular 3/4 axis programming but not had to do much with the integrex`s lock/unlock spindles etc)
Please can someone point me in the right direction with regards to a program for this.
What I want to do is
1) Move Milling tool into position (off in Y)
2) Feed into cut (lathe spindle stationary, milling spindle rotating)
3) Mill along dia (both lathe and milling spindle rotating)
4) stop lathe spindle and retract tool.
Any help/pointers will be greatly appreciated.
Best regards
Harry
Best regards
Harry
