Turn QT 28N
evilpieceofdust
Mar 28, 2017
Hello people,
The machine has Serial number M325L0214Z9, Model FCA325L2NJ-1
In the attached documents is the list of parameters for this machine. Some fields say (set the best value to ech machine) and here we need support to complete the fields.
Mazak QT 28N parameterlist 1.jpgMazak QT 28N parameterlist 5.jpgMazak QT 28N parameterlist 2.jpgMazak QT 28N parameterlist 3.jpgMazak QT 28N parameterlist 4.jpg
Then I was NOT correct, Its a T32 system with 2 axis (X and Z)
I can find these parameters:
T5 Tooleye brake on time (standard 50)
T6 Tooleye brake off time (standard 20)
T7 Time movment of tooleye (standard 80)
B61 Toolnose measurment sensor width X-axis
B62 Toolnose measurment sensor widht Z-axis
B63 Toolnose measurment sensor position X-axis
B64 Toolnose measurment sensor Position Z-axis
I can check later today if I can find out the others.
TO GO FROM EEPROM TO RAM.
1)Goto PARAMETER page.
2)Push 3rd menu button from right.
3)Key in 1131 and area above button will highlight in purple.
4)Goto DIAGNOSTIC page.
5)Press DIAGNOSTICMEMORY.
6)Press MEMORY EEPROM.
7)Move Curser down to EEPROM.
8)Key in 2, Press INPUT, and Then START.
Take picture of all your parameters first :)
the procedure of loading the parameters from EEPROM is done. all is functioning well and all the alarms are gone.
Thank you respectfully!
Hello My Friends, i have one problem with the key. I don't know where the key is, to be able to put the 1131... could you tell me what the key is or a photo? many thanks!! A hug
