Turn QT 28N
Results 1 to 10 of 10
Thread: Turn QT 28N
    Mar 2017
    ROMANIA
    5
    Default Turn QT 28N
    Hello people,
    The machine has Serial number M325L0214Z9, Model FCA325L2NJ-1
    In the attached documents is the list of parameters for this machine. Some fields say (set the best value to ech machine) and here we need support to complete the fields.
    mazak-qt-28n-parameterlist-1.jpgmazak-qt-28n-parameterlist-5.jpgmazak-qt-28n-parameterlist-2.jpgmazak-qt-28n-parameterlist-3.jpgmazak-qt-28n-parameterlist-4.jpg
    Feb 2015
    SWEDEN
    584
    102
    276
    Is this a T-2?
    Mar 2017
    ROMANIA
    5
    you are correct, the control is a T32-2
    Jul 2006
    Arizona
    4,656
    18543
    4443
    Quote Originally Posted by benganboll View Post
    Is this a T-2?
    I think it's a T-32 control. I have never seen a QT28N with a T-2.
    Mar 2017
    ROMANIA
    5
    The control is T32-2
    Feb 2015
    SWEDEN
    584
    102
    276
    Then I was NOT correct, Its a T32 system with 2 axis (X and Z)
    I can find these parameters:
    T5 Tooleye brake on time (standard 50)
    T6 Tooleye brake off time (standard 20)
    T7 Time movment of tooleye (standard 80)
    B61 Toolnose measurment sensor width X-axis
    B62 Toolnose measurment sensor widht Z-axis
    B63 Toolnose measurment sensor position X-axis
    B64 Toolnose measurment sensor Position Z-axis
    I can check later today if I can find out the others.
    Feb 2015
    SWEDEN
    584
    102
    276
    Have you tried to reload parameters from eeprom?
  8. Likes Philabuster liked this post
  9. #8
    Feb 2015
    SWEDEN
    584
    102
    276
    TO GO FROM EEPROM TO RAM.
    1)Goto PARAMETER page.
    2)Push 3rd menu button from right.
    3)Key in 1131 and area above button will highlight in purple.
    4)Goto DIAGNOSTIC page.
    5)Press DIAGNOSTICMEMORY.
    6)Press MEMORY EEPROM.
    7)Move Curser down to EEPROM.
    8)Key in 2, Press INPUT, and Then START.
    Take picture of all your parameters first
  10. Likes Philabuster, cnctoolcat liked this post
  11. #9
    Mar 2017
    ROMANIA
    5
    it was my mistake for the controller.
    Nice that you know the parameters by function and thank you for your time!
  12. #10
    Mar 2017
    ROMANIA
    5
    the procedure of loading the parameters from EEPROM is done. all is functioning well and all the alarms are gone.
    Thank you respectfully!
  13. Likes Philabuster, benganboll, cnctoolcat liked this post
