David_M
Hot Rolled
- Sep 30, 2014
- Midway, GA, USA
It is a Japanese made QTN 200 model from the early 2000's. I did not get the EIA/ISO option.
I would like to machine some delicate Teflon parts that have a central 3mm hole. I plan to use a hardened and polished rod as a dead center in the hole's entrance. It's important that the tailstock not apply any thrust, though.
Is it possible to set the tailstock to work this way with code or with a changed parameter?
Edit: I wonder if I could use 'Set Home Position' to help out some way?
Thanks!
David_M
Thanks!
David_M
