My V5 needs serious help. It will not retain tools. Therefore I need some ideas about how to go about swapping out the stack.
For starters the machine is a '83; apparently a bit after Mazak switched from pulling the spindle out the bottom to removing it from the top.
With out going on forever a basic outline of what is needed to replace those 100+ washers (spring) that tension the fingers that hold the retaining knob. Any help is appreciated. Thanks in advance.
