CNCToolCat's Cat-House - Page 12
Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 221 to 240 of 252
  1. #221
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Default CNCToolCat's Cat-House
    So, after having a good 2019, it was time to spend a little money and improve the shop a bit for 2020:
    This Craftsman set is from Lowe’s, and is good quality for the money. Plus, the boxes are “Made in USA with global materials”.
    So, for about the same money as the Chinese-made tool boxes from Home Depot and Harbor Freight, it was Craftsman for me...I buy USA when possible.
    (I’m too cheap to shell out the big bucks for Vidmar, Lista and the like. In my opinion a cabinet is a cabinet, as long as the drawers open and close, it’s all good.)
    Plus, a little new pallet rack action to help organize finished parts inventory:
    I also installed Mitsubishi 0.4kw VFD’s to control the chip conveyor motors on the two QT28N lathes. Even with gear reducers, the original Jorgensen conveyors just ran too fast.
    Now, they are smoothly rolling along at half speed, 30 hertz on the VFD’s. Plenty fast enough, and by cutting the speed in half, theoretically you double the life of the chip conveyor!
    I added an auxiliary contact on the coolant pump contactor, to control the start/stop of the conveyor VFD’s. I like the conveyors to only run when the coolant is on.
    The main 3-phase power to the VFD comes off the original conveyor contactor, which is ON all the time. (To the right of the coolant pump contactor in the center.)
    Notice my "git r' done" approach, direct wire connections to the auxiliary contact on the coolant contactor, and use of a standard 14 ga. power cord for the VFD motor-start circuit.
    Happy New Year to fellow PM’ers, hopefully it will be busy and prosperous for us all!
    ToolCat Greg
  2. Likes CBlair, Garwood, wheelieking71, SND, RF and 4 others liked this post
  3. #222
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Oh, I almost forgot, I also picked up a Tschorn 3D indicator...after 23 years in business it was about time!
    (Although to be fair, we do mostly turning work here at the Cathouse, using the Mazak VTC-16 mill only about 5 days a month, on a couple regular jobs that stay set up. I use the mill of course for tooling and little projects...and that's what this thing will really help with!)
    These things should be mandatory on a vmc. It actually makes setting up a job fun!
    I like this Tschorn model (actually the SavePlus “value” model), the spacing between graduations is nice and wide. It is only 50mm per revolution, requiring four full turns of the large needle to reach zero on the small needle.
    Some 3D indicators are 100mm per revolution I believe? ...do they reach zero in two turns?
    (I like having four turns to zero --- more safety cushion!)
  4. #223
    Apr 2019
    Arkansas
    1,241
    519
    444
    Wait until you get an integrated probe CNCToolCat's Cat-House you will be even more gitty when it does math for you and tells you the diameter of that ring.
    Sent from my Pixel 3 using Tapatalk
  5. #224
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Public service announcement:
    Check your coolant tanks!
    Some re-purposed Mazak sheet metal worked perfectly as a horizontal divider between the coolant and chip conveyor. (The original pieces were missing...)
    ToolCat
  6. #225
    Aug 2002
    West Unity, Ohio
    26,054
    6353
    8513
    What was y'all lookin' fer in there?
    You know that there aint no Cadillac in the bottom of a Crackerjack box eh?
    Coolant tanks and brake lines should be made out of SS!
    Think Snow Eh!
    Ox
  7. Likes as9100d, JP Machining liked this post
  8. #226
    Apr 2007
    Pillager, MN
    5,884
    1912
    5441
    You mean you need to clean those every now and again?.......huh.................who'd a thunk.
  9. #227
    Oct 2005
    NORWAY
    934
    408
    201
    How long did it take to get that bad ? Interesting to see how much goes through the conveyor.
  10. #228
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Quote Originally Posted by Panza View Post
    I didn’t realize it, but it had been almost four years since I got this QT28 into service!
    This machine runs 4140HT hot-roll bar exclusively, and the hot-roll scale builds up pretty bad.
    We’re gonna put all three of the big Mazak lathes on a regular schedule for coolant-tank cleaning.
    The irony is there were no symptoms of this chip/sludge fiasco, the high-pressure pump was never starved, and the coolant never stank! (We do skim the lube oil off the coolant daily using shop vacuums).
    ToolCat
  11. Likes Panza liked this post
  12. #229
    Sep 2002
    Lawrenceville GA USA
    6,282
    858
    1383
    Quote Originally Posted by cnctoolcat View Post
    ToolCat
    I have to clean out the coolant tank on my mill twice a year. I make almost exclusively small parts and that means small tools and small chips. I start to notice that I have to top off the tank more frequently. That is because the small chips start to take up the tanks capacity. I will get about 2/3 or more of a 5 gallon bucket each time I clean the tank.
    I tried to put some screening material on top of the perforated screen but none of the three products I tried, home center stuff, worked all that well. Most got saturated and I had coolant running over the top and on the floor.
    Have a good weekend and thanks for sharing.
    Charles
  13. #230
    Apr 2007
    Pillager, MN
    5,884
    1912
    5441
    Prolly 10 gallons of coolant and 40 gallons of chips in that Mazak.........................
  14. Likes CBlair, ranchak liked this post
  15. #231
    Jan 2006
    New York
    1,615
    699
    791
    Doin the nasty!
  16. #232
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Recently I sold a couple machines to a buddy who has a shop in the next town over.
    We said goodbye to the trusty Fadal 3016, as we only ran it a couple days a month. The floorspace became more important than the machine, as I have a Mazak vmc to run the one job on.
    Also, I sold the ‘ol trusty QT10N, which had actually been in storage inside a container out back of the Cathouse.
    I sold the machines with a “start up guarantee”, which did require a little sleuthing for the Mazak, as she was quite temperamental after having been stored for 2-1/2 years! But, with my stock of spare boards, I was able to bring the ‘ol girl back to life in good shape.
    Here’s some pics of the loading out at the Cathouse:
  17. #233
    Aug 2002
    West Unity, Ohio
    26,054
    6353
    8513
    A) What's with the "Sold" sign?
    B) Is that Fadal actually listing to one side?
    Think Snow Eh!
    Ox
  18. #234
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    My friend Charlie was too tight to hire an air-ride truck to haul the machines on, and I was fretting the straight truck’s rough ride would really test my “start up guarantee”!
    The machines only had to go about 15 miles, and were none worse for the trip.
    Here’s the machines in their new home:
    While the riggers were gone with the first machine, the guys and me proceeded to move one of the gear hobs — we wanted to re-arrange both hobs to have a better work area.
    We did enlist the rigger’s help to move the second machine when they got back. It was their forklift after all....
    Here’s the original gear hob layout (notice the container outside where the QT10N was stored):
    And here’s the new layout:
    ToolCat Greg
  19. #235
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Think Snow Eh!
    Ox
    The "Sold" sign was just a little shop humor...
    The right fork on the big yellow lift was a tad lower than the left one, and did create some lean on the machines when loading. However, the Fadal isn't leaning near to what she looks in the picture...I reckon the camera angle exaggerated the lean??
  20. Likes Ox liked this post
  21. #236
    Oct 2005
    NORWAY
    934
    408
    201
    This machine runs 4140HT hot-roll bar exclusively, and the hot-roll scale builds up pretty bad..
    When I'm running steel it is mostly 4140HT hot rolled too. I'm wondering what sort of surface speed and inserts you are using ? At the moment I am running Iscar IC908 grade in CNMG and DCMT for OD work. Around 150-175m/min. I guess that is 492-574 SFM ? I have been running up to 200m/min but the inserts can't take that for more than a few minutes. I have ran some sandvik inserts for roughing but what they recommended didn't last as long as the Iscar inserts.
  22. #237
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    For your viewing entertainment, here’s my entry for “chaotic chatter”:
    Also entering the “biggest burr” category:
    The “filthiest fan” entry:
    And, the “most belts” entry:
    Not to be outdone, the “most grease” entry:
  23. Likes Ox, wheelieking71, Philabuster, david n, SND and 3 others liked this post
  24. #238
    Aug 2006
    montana
    400
    229
    166
    You change your inserts as often as you clean your coolant tank.LOL
  25. Likes wheelieking71, SND, CBlair liked this post
  26. #239
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    Over the years I have learned to work on the electronics of my older Mazak’s, replacing capacitors, transistors, hybrid chips, IGBT modules, repair bad traces,...anything I could do to resurrect a dead drive or board.
    I had always used solder wick and my Hakko solder station to desolder components, up until a while back when I scooped up a good deal (via fleabay) on a Hakko desoldering station — and man, after new filters and a good cleaning, it does the job!
    Anyway, here’s some random pics of the “guts” of various Mitsubishi spindle and servo drives, power supplies, and boards used on 80’s-90’s generation Mazak CNC lathes.
    I do all my electronics repair stuff at home. Oddly enough, I find it therapeutic to set down with a cold beer and do a little solder work.
    Here’s my Hakko desoldering station:
    ToolCat
  27. Likes SND, DrHook, Garwood liked this post
  28. #240
    Sep 2006
    Abingdon, VA
    3,482
    4708
    3323
    ...and a few more pics:
    ToolCat
  29. Likes SND, Garwood liked this post
