CNCToolCat's Cat-House - Page 3
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 41 to 60 of 220
  1. #41
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    Here's some pics of the splined shafts we make:
    I purchased two Barber-Colman 16-16 gear hobbers from a dealer (via Ebay of course!), for just a bit above scrap value. These 16-16's were the standard of the gear cutting industry for many decades, with thousands of them still out there in daily use.
    The machines are late 70's models, which is near the end of the production run by BC. They came out of Caterpillar in Joliet, IL. These machines are mechanical marvels! When you look at the exploded views in the parts manual, it will blow your mind!
    I had to do some tuning on them, adjust this here, fix that there. The main drive pulley on one was wallered out, so I removed the shaft, turned it down, made a bushing, and fixed that mess. The other had a main gear that was slipping a little on a shaft, so a new moon key and loctite fixed that. One machine had a stuck reversing-contactor, so I took that apart and fixed it. (May have been the reason Cat surplused the machines??) I rewired motors to run on 240V, and made adapter plates and installed new, self-centering 4-jaw Bison chucks (Ebay).
    I had a helluva time getting a good finish on the splines when I first started. I had noticed the same finish irregularities in my competitor's shafts, and I wanted to do better!! After tightening and tweaking everything I could, I was about to just accept the finish and drive on, as Ox says.
    But one day, I was at a good customer's plant (where I used to work), and noticed they were hobbing a big gear on a 16-16, and getting a great finish! Hmmm, what's up here?? Well, just by sheer dumb luck, as they were not running the machine at the time, I did notice by how the machine was parked that they were _climb_ hobbing. Could this be the secret?
    I ran back to the shop, installed another idler gear in the feed box, which reverses the direction of the carriage feed, threw a part in, and cut away. As it was climb hobbing, I could not believe my eyes!! The finish was obviously better, and the cutting action was way smoother as well.
    I figure the old girls must have climb-hobbed their whole life, and the wear patterns in all the gearing and shafting and ways just liked the climb better. So that is my secret. (Don't tell the competition!) I can honestly lay my shaft on the desk beside another shop's shaft, and it's easy to see which splines have a better finish.
    On edit: Whew...I finally was able to resize a shot of one of the 16-16's. I load directly from my computer, versus from Photobucket...
    Catman
  2. #42
    Jan 2010
    Indianapolis, Indiana, USA
    5,473
    2426
    931
    I like the climb hob story. Some luck and some (customer-focused) obsession can go a long way towards doing great work.
    Regarding the machine's trip from Illinois to Virginia, I'm wondering how that was accomplished. Did you trust a carrier, or did you go fetch them yourself?
  3. Likes Laurentian liked this post
  4. #43
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    I use a freight broker to line up flatbed truck transport. Usually has other stuff on the truck, so cost isn't as bad as you might think. About $1000 I believe from IL to VA, back in 2009. Local rigger unloaded and set them for me.
    I just now realized I didn't post overall pics of the gear hobbing machines! Yet upon trying to do so, the file sizes are too big! So, I will have to take more pictures with my smaller camera next week, and post some then.
  5. Likes S_W_Bausch liked this post
  6. #44
    Aug 2002
    West Unity, Ohio
    25,271
    5545
    7971
    You doo realize (well, I guess you don't - dumb question) that you CAN resize pics?
    You can even save the smaller one sepparate from the original in case you don't want to lose the big file...
    If you load them to Photobucket, they will resize for you automatically.
    I am Ox and I approve this h'yah post!
  7. #45
    Jan 2010
    5,473
    2426
    931
    I use the Paint program (that comes with Windows) to resize photos.
    Get the image into Paint.
    Click on Image.
    Select Stretch.
    Enter some % (less than 100%) for Horizontal and Vertical axii.
    Then Save As .JPG.
    You may also find that simply opening the image in Paint and then Save As .JPG will reduce the size of the image by 50% or so. I just confirmed with a 640 by 480 image. Camera created it as 117kb, after simply Save As with Paint, it shrunk to 60kb.
  8. #46
    Feb 2011
    Pensacola, FL
    1,308
    154
    809
    Thats some great looking work on those shafts Catman, and loved the story about the B/C machines.
  9. #47
    Mar 2008
    Canada
    1,100
    5795
    197
    RESPECT catman !
    I'll be asking you the paint code on the Mazak's for
    our QT8 soon enough
  10. #48
    Dec 2006
    CANADA
    Ontario
    983
    90
    142
    Which of the lathes is in the pics?
  11. #49
    Jul 2006
    Arizona
    4,594
    18440
    4308
    Cool Keep the pics coming, Catman.
    Quote Originally Posted by S_W_Bausch View Post
    Click on Image.
    Select Stretch.
    Then Save As .JPG.
    Much easier way is to install free Microsoft Powertoys Image resizer. Works with XP and newer. Really easy to use. Right click on a single picture (or group of selected pics), click 'resize image' now in the right click drop down menu, select the desired image size, then click OK.
    Resizer will make a copy of the resized image and add (Medium) at the end of the file name if you selected medium size (800 x 600 pixels).
    Resizing images on the computer makes uploading to Photobucket or Craigslist MUCH faster. No need to upload a 4 Meg file when CL will just resize it to 20kb anyway.
  12. #50
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    Here is some pics of the 1985 Mazak QT20N that I bought back in 2006. The machine was a mess when I got it...as the first 3 pics show. Took lots of cleaning and sanding to get her ready for paint. I had to have new sheet metal made. The original door looked like it had been hit with a grenade, the firewall had been beat up, and the sliding Z-axis way cover was bent all to heck.
    Mazak actually could provide the new sheet metal parts, but at a cost that was frightening! So, I had a local laser/sheet metal shop cut me new pieces, that I was able to use to make all new parts. For the door, I used the edge detail from the old door, and welded a new flat panel on the front, to make a like-new door. The firewall was rebuilt in a similar way, I used the edge details of the original, and welded on a new flat sheet. JB Weld was used as "bondo". The sliding Z-axis cover was basically just a big piece of sheetmetal, bent at 90 degees, a few tabs welded on, and it was good to go.
    The gearbox seen in pic 2 had noisy gears. Mazak wanted $5k for 4 new gears, so to heck with that. I had successfully removed the gearbox on an older QT10, so that's what I did here. A new 1" thick aluminum mounting plate moved the spindle motor over to the position of the original gearbox, and new belts took care of that. The machine has a 20hp (peak) spindle motor, with pulley reduction, and since I do almost no large diameter work (larger than 8" o.d.), not having the gearbox has never been an issue. The spindle is smoooooth....
    (More pics on the next post...)
    backuppictures-312.jpgbackuppictures-313.jpgbackuppictures-314.jpgbackuppictures-310.jpgbackuppictures-273.jpg
  13. Likes Philabuster, Jashley73, cpifer3, MotoX liked this post
  14. #51
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    Ok, here's more pics of the rebuilt QT20N.
    First pic shows new spindle drive setup, without the gearbox. Motor mounted on new aluminum plate where original gearbox was.
    Second pic shows rear of carriage, with new Z-axis cover visible. Notice the size of the Z-axis box ways!
    Third pic is coolant tank ready for paint. It had lots of pitting on the inside. After wire brushing and thoroughly cleaning, I used liquid Devcon to line the inside of the bottom of the tank. So far so good...
    Pic 4 shows (nearly) completed machine, with chip conveyor I sourced via Ebay!
    backuppictures-281.jpgbackuppictures-285.jpgbackuppictures-309.jpgbackuppictures-289.jpg
  15. Likes Philabuster, Lyk31337, zoeper liked this post
  16. #52
    Apr 2007
    Pillager, MN
    5,731
    1868
    5226
    She sure is purdy.
  17. #53
    Jan 2007
    Annapolis, Maryland
    530
    744
    288
    Man - you do nice work toolcat...
    Brent
  18. #54
    Jan 2012
    Ohio, USA
    361
    381
    133
    Default Re: CNCToolCat's Cat-House
    Mazak blue everywhere. Man that must be fun restoring those, especially to the extent you do. Great looking shop.
  19. #55
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,982
    1455
    2412
    Cool thread, cool shop catman.......glad OX got you going in it agin...
  20. #56
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    Some more random pics:
  21. Likes Lyk31337, Philabuster liked this post
  22. #57
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    And a few more:
  23. Likes Philabuster, TheOldCar liked this post
  24. #58
    Aug 2002
    West Unity, Ohio
    25,271
    5545
    7971
    An American flag hanging behind a YaMazaki?
    He stopped loving her today...
    Ox
  25. Likes cnctoolcat liked this post
  26. #59
    Jan 2013
    Gilbert, AZ
    5,864
    7384
    7459
    those worm screw looking shafts look like they were fun! nice job. details on the process? and whats the major O.D.? hard to tell how big they are in the pic.
    I really like your shop. personally HATE Mazatrol, but am fully aware of how awesome Mazak's are. You do a fine job of putting them back in service. VERY COOL!
  27. #60
    Sep 2006
    Abingdon, VA
    3,353
    4486
    3100
    Here's some pics of machines being worked on:
  28. Likes Philabuster liked this post
