Tried and True Machine - Page 40
Page 40 of 40 FirstFirst ... 30383940
Results 781 to 798 of 798
  1. #781
    Apr 2007
    Pillager, MN
    6,231
    1925
    6030
    There's some pretty good lead times on labor here too...............
    I would have everything lined up but the framing. And I think I could scrounge together a crew and bang it out in a few weekends. It's just a big box after all. I could end up doing quite a bit of the work myself any ways. Hire out the dirt work. Setting concrete forms ain't bad on a slab. Infloor heat and plumbing a trained monkey could do and is really only a day or two of work. Got a friend that does great masonry work and he'd get me into the schedule for the flat work..........Insulation is a day or so of itching.............and I would wire it myself anyways...........as soon as you mention 3PH and EMT to an electrician, the price seems to quadruple................At least now I have 2 teenagers................gotta love slave labor.
  2. #782
    Jan 2013
    Gilbert, AZ
    7,044
    9303
    9142
    Yea, I plan to do mine myself. The big hold-up for me right now is: there is a big old AC unit on a stand in my way.
    I need to get it hanging on the wall. I bought the steel to do it months ago. Been tripping on it for way too long, LOL.
    I have a good concrete guy. He is less than a month out at any time. I will frame it with sticks, easy-peasy.
    The big hurdle for me (beyond hanging the AC) is the tin-work on the outside to make it look like it belongs.
    I know nothing about it. I've never done it. I know where to buy the materials. But, don't know what I need.
    I'm gonna have to dive in pretty soon though as I am completely out of room in here. Its pretty bad right now.
  3. Likes DrHook liked this post
  4. #783
    Jan 2007
    Annapolis, Maryland
    545
    774
    299
    What am I seeing for the current 'inventory'?
    Mills:
    1 Haas
    1 Doosan
    1 small Brother
    Lathes
    1 Haas
    2 Doosans
    Nice Shop!!
  5. #784
    Oct 2009
    Oregon
    5,899
    6395
    3269
    Quote Originally Posted by wheelieking71 View Post
    First building I built I went to a local steel siding roller and asked tons of questions. They were super helpful and got me exactly what I needed. Take some pictures of the trim pieces and rodent guard your building has to take with you so they can match it.
    Try to figure it out well enough that you get all the straight stuff cut to exact length. Cut most of the other stuff with a metal blade in a skilsaw.
    Finger out your screw pattern, stack the sheets and drill each wall in a stack.
  6. #785
    Apr 2007
    Pillager, MN
    6,231
    1925
    6030
    Ugh.................
  7. #786
    Jul 2006
    Hillsboro, New Hampshire
    12,475
    2854
    8671
    Quote Originally Posted by david n View Post
    I think the front fell off...
  8. Likes bryan_machine liked this post
  9. #787
    Sep 2006
    Abingdon, VA
    3,647
    4904
    3588
    Looks like the draw tube itself is a little thin, the factory is trying to maximize through-hole size I would imagine.
    If you make a new draw tube, I would use heavier-wall tubing, give up a little through-hole capability for part integrity.
    My 2 cents!
    ToolCat
  10. Likes RF liked this post
  11. #788
    Feb 2001
    Redwood City, CA USA
    5,247
    226
    1107
    I hope this happened while actuating the chuck and not when spun up with a workpiece.
  12. Likes wheelieking71 liked this post
  13. #789
    Jan 2013
    Gilbert, AZ
    7,044
    9303
    9142
    Quote Originally Posted by rklopp View Post
    Yea! What he said! I would not want to see a rogue chuck @ 3500rpm!
  14. Likes bryan_machine liked this post
  15. #790
    Jan 2003
    Canada
    11,569
    6352
    3724
    Is that in the old lynx or the haas?
  16. #791
    Apr 2007
    Pillager, MN
    6,231
    1925
    6030
    Nothing dangerous or scary happened...................this is on the older 220LC Lynx. The draw tube basically pulled outa the collet chuck draw nut. The draw tube has two slots/notches to for removal and installation. That's where it failed. The draw nut on the FlexC chuck doesn't have much thread length and I think that is the problem. Prolly 5/8" or so. The 3 jaw chuck's draw tube nuts have at least double that length. I have to get on the horn with Hardinge and see if they can make a nut with longer threads. I can bet they'll say it was my fault it failed, too high of clamp pressure or something. I run the pressure where I'd run a 3 jaw.
    I was down for less than 24hrs...............Doosan had a replacement tube at my door the next day.
  17. Likes Mr.M, Ox, CBlair, wheelieking71 liked this post
  18. #792
    Sep 2012
    Minnesota
    268
    78
    94
    Unity Tool has made many drawtube adapters if you need. I used them many times in the past.
  19. #793
    Jan 2003
    Canada
    11,569
    6352
    3724
    Good to know. I had the feeling there wasn't that many turns of thread when I put the Flex-65 on my lynx2100.
    I run it at 300psi I believe, near max for it anyway.
    Was it much work to change the tube? I never saw one apart, can you unscrew/pull it through the front or gotta undo the actuator at the back?
    Maybe I should keep a tube here in stock...
  20. #794
    Apr 2007
    Pillager, MN
    6,231
    1925
    6030
    Quote Originally Posted by SND View Post
    Just unscrew it and pull it out inside the machine....................Since the slots in mine were unusable, I had to take the angle grinder in there and put in new ones. Screwed right out.................slathered the new one up with antiseize and screwed it in................
    What FlexC chuck do you have? This machine has the pull back style. The new rig has the push to close chuck......
    This chuck has 12 studs/dowels that link the nut to the collet "gripper". There's an M6 x 50 cap screw through each. When I pulled everything apart to clean, 3 of the 12 had snapped cap screws and the other 9 where not very tight. That's something else I have to talk with Hardinge about. Wonderin' if'n they were never tight from the factory...................
  21. #795
    Apr 2007
    Pillager, MN
    6,231
    1925
    6030
    Quote Originally Posted by Mr.M View Post
    This one is specific to the collet chuck...................not just a plain ol nut...................
  22. #796
    Apr 2007
    Pillager, MN
    6,231
    1925
    6030
    Quote Originally Posted by cnctoolcat View Post
    My 2 cents!
    ToolCat
    Never gonna happen..............I need all the through hole I can get..............plus the pile of spindle liners would be useless.........................
  23. Likes wheelieking71 liked this post
  24. #797
    Aug 2002
    West Unity, Ohio
    27,213
    7643
    9454
    The amount of engagement is likely fine for normal conditions, had the end of the tube not been slotted.
    You could maybe step up to 4130 or such tube if necessary.
    Think Snow Eh!
    Ox
  25. #798
    Jan 2003
    Canada
    11,569
    6352
    3724
    I'm glad to hear they're not too hard to replace.
    I have the Flex-C pull back style with dead length stop. I never took it apart to clean it yet, but I only have about 330hrs on it so far.
    I put an aluminum ring on mine so it slings to coolant away from the spindle face, similar to the Royal design. I didn't like how it left too much of it exposed with the smaller OD of the hardinge design.
