.050r max
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: .050r max
    Aug 2015
    Florida
    9
    Default .050r max
    This should be a simple question, but it seems as we have a slight discrepancy in the way a print calls out a radius. If a print says .050R MAX, could it be 0? To me, anything under .051 should be acceptable. even if it is 0.
  2. Likes Eric M liked this post
  3. #2
    May 2007
    Massachusetts
    828
    13
    70
    .0509 is over the spec, so, no. Under .051 is not acceptable. Zero is.
    Sep 2015
    Ohio
    993
    563
    971
    That's the way I read it, although I usually put some kind of radius. Usually whatever tool I have that has a radius under .050 that way I don't have to buy anything special.
    Apr 2015
    Connecticut
    428
    247
    181
    Yeah anything at or under .05 is acceptable even a square corner.
    Oct 2016
    Florida
    238
    514
    155
    Dumb ass engineers and production design people come up with more stupid dimensions and tolerances
  7. Likes Gordon B. Clarke liked this post
  8. #6
    Jun 2012
    Michigan
    9,476
    3234
    3396
    likely worried about Interferences in corner .. I have seen that often on grinding part prints.
    QT: [anything under .051 should be acceptable.] perhaps with +- .001 or +- .005 on some prints... *but I would not take the chance for argument and hold .050 and less...
  9. #7
    Jun 2013
    Oregon
    1,422
    505
    859
    Quote Originally Posted by TiTillIdie View Post
    Zero is nothing. If it calls for a radius, and you give it zero radius, there is no radius. The part is wrong.
  10. Likes Larry Dickman, Dupa3872, J Gilles liked this post
  11. #8
    Jan 2014
    Temecula, Ca
    2,549
    1179
    3353
    Quote Originally Posted by Gobo View Post
    I would agree that if you put a sharp corner, you're asking for trouble.
  12. Likes Kai Kendall liked this post
  13. #9
    Jan 2014
    Temecula, Ca
    2,549
    1179
    3353
    On the other hand, we have parts where they DO want a sharp corner, and they will call out .005r max. So I'm not really sure.
  14. #10
    May 2017
    Minnesota
    686
    589
    359
    I sincerely doubt the part is made to an atomically perfect sharp corner. If it isn't, there's a radius.
  15. Likes AARONT, beege liked this post
  16. #11
    Oct 2010
    Oregon
    4,901
    3923
    1766
    A sharp corner satisfies 0.050R MAX. Sharp inside corners are not good ideas, but it's the customer's job to specify the tolerances. As michiganbuck said, this is almost certainly to ensure that this part and some other part will seat properly without interference.
  17. #12
    May 2010
    DENMARK
    2,454
    3904
    13297
    Whoever "designed" it doesn't want a sharp edge so any small radius under 0.05 is OK. A small chamfer would/could also be regarded as having sharp edges.
  18. #13
    Jan 2007
    Flushing/Flint, Michigan
    7,209
    344
    6079
    There is no min spec. and you can't make a "zero" anyways.
    You are correct. Anything below .050 plus whatever the tolerance block gives.
    Bob
  19. #14
    May 2004
    2,493
    885
    1616
    Bob
    I disagree. Title block tolerances are for stuff not otherwise specified. ".050 Max" is specified, therefore title block tolerances don't apply. No?
  20. #15
    May 2010
    DENMARK
    2,454
    3904
    13297
    This is making a mountain out of a molehill. An R is stated and this means a radius. What is called for is a radius no larger than 0.05. Sharp edges and chamfers are not radii.
  21. #16
    Jun 2006
    Hawthorne, CA USA
    195
    41
    66
    Is the drawing per ansi y14.5 or asme y14.5? A "R" is a boundry and any shape inside the boundry is acceptable excluding reversals. A "CR" is a controlled radius and must be a fair arc with radial control.
  22. #17
    May 2010
    DENMARK
    2,454
    3904
    13297
    Quote Originally Posted by in2glamisgirl View Post
    I don't doubt that you're correct but the drawing probably didn't reference any standard. I can't help but think that R.03 ±.02 would have solved all problems.
  23. #18
    Jun 2012
    Michigan
    9,476
    3234
    3396
    Perhaps good to hand hone break the cutter corner about .000012 if that is a concern to producing the job. We would leave the corner .050 to zero radius for grinding parts and never got a job back. Most often to 3/64 or less (to zero) just to save the time of checking on the shadow graph. Yes grinding is different because it is near impossible to get a dead sharp corner. Adding a .005 radius would often include a wheel change , face and OD dress, blue-up, hand feel the floor of the part. slow come-in and careful watching. likely a 1/4 hour addition to part cost. Yes a dressed radius would not be performed, just going to the smaller grit wheel would get the desired smaller radius.
    Even employing that hand hone bump to the end mill might defeat the designers purpose of saving the time and additional cost of adding a radius to the part..The cost of a special .025/,030 radius end mill might be $100 or so, add a tool change, tweak the extra pass into the program, hold the job up three days to consult the PM guys, give you dog a dirty look because of being upset, loose a nights sleep in worry,
  24. Likes camscan liked this post
  25. #19
    Jul 2009
    hope,in
    643
    29
    39
    My take is a sharp corner meets spec. Max is max. I do run into the used of max and min where it does not work correctly. usually min. If min. then the part would not have a shoulder as an example. Now if they needed a radius for stress relief, then they could spec in and under cut radii.
  26. #20
    May 2005
    AZ
    2,296
    207
    784
    I'm also in the camp of "Sharp to .050 R is acceptable". I have ALWAYS interpreted this specific designation, not as a feature specification per se, but an allowance for configuration based on shop options, tooling at hand, and designer's functional requirements. I don't think that because it says "R" that a radius is being mandated. And as Larry Dickman notes, this type of note is often used to indicate intent of sharp corner in the context of ".005R max". When the nomenclature "CR" is used, that IS a specification for a radius.
  27. Likes Cole2534 liked this post
