Accu-rite scale pin out
Likes Likes:  0
Results 1 to 3 of 3
    Sep 2005
    Northern California
    1,101
    182
    Default Accu-rite scale pin out
    Accu-rite seems to have two connector styles for their readers circular and oval
    Does anyone have pin-outs for both style connector? I am assuming that both glass scales are otherwise similar if not identical.
    Jan 2007
    Flushing/Flint, Michigan
    10,580
    619
    8551
    Do you know the difference between a sine wave scale and a square wave scale just for the starting point?
    The connectors different on purpose. The guts or "brains" in the scale not the same.
    Dec 2013
    Fort Wayne, IN
    860
    879
    307
    It would be easier to know what scale you have and what you are trying to accomplish. The round 6 pin connector and the ENC/SENC-150 scales both used a 5V TTL signal. However, the Mate scales used a analog signal that is not compatible with any other Acu-Rite or Anilam DRO system without the proper interface cable to translate the signal.
    The glass is completely different between even different models utilizing the same plug.
    All 3 pinouts are readily available in the documentation portion of Acu-Rites website. I would still be curious as to what exactly you are needing this information for.
    Jon
