Ball bars in the UK?
Likes Likes:  0
Results 1 to 7 of 7
    Sep 2008
    Leics UK
    42
    Default Ball bars in the UK?
    Hi All,
    I need to purchase a Ball bar so I can calibrate a metrology system.
    Seems like a 200mm ball bar would be an off the shelf sort of item, but I cant find a UK supplier....
    Any leads gratefully received.
    cheers
    Dave
    Jul 2002
    Maryland
    4,390
    714
    575
    what about http://www.precisionballs.com/products.htm ?
    You might have to poke around to find what else they may have.
    Feb 2009
    San Diego, CA
    288
    you cant get renishaw in the uk? They're based out of there if i'm not mistaken.
    http://www.renishaw.com/en/6813.aspx
    I think this is the one we had where i used to work.
    Sep 2008
    Leics UK
    42
    BalTec (precision balls) is the only place Ive found them off the shelf so far, but they are in the USA...
    The Renishaw kit looks like a sensor in a ball bar shape if you see what I mean.
    I didnt think that a simple, solid one piece ball bar would be a difficult item to find, but my google skills must be lacking....
    cheers
    Dave
    Sep 2002
    Salinas, CA USA
    3,869
    197
    172
    Dave, here is a source of used ballbars, they have one for $50, says it has several lengths in the kit:
    http://www.omnicmm.com/equipment/1035.pdf
    Sep 2008
    Leics UK
    42
    Ok, I cant get one in time, so Im having to 'roll my own'...
    I can get precision balls with holes in them and 1/2" dia carbon fibre tube. then I have a little CMM time booked, so for this demo it looks like I can squeek by...
    cheers
    Dave
    Sep 2008
    Leics UK
    42
    Just thought Id post a quick update.
    Rolled my own, using CF tube and precision 316 stainless balls. Cut the tube with a hacksaw, aiming for a nominal CC length of 175mm. Dead happy when it came back from calibration at 175.3mm
    Also had to make a mount to attach it to our automated pan tilt stage. Split wedge type clamp, fits into the hole in the stage top plate.
    Dave
