I have taken over a Mazak VCN510c with renishaw probing. It has had the tool probe removed several times a year to do a part that takes up the majority of the table. The part probe has also not been calibrated in years. I plan on “permanently”mounting a piece using the bolts on the side of the table to easily be able to recalibrat the part probe. So my questions are as follows.
1. What is the best order for recalibrating the machine, as in tool or parts probe because I will have to machine the piece to calibrate the part probe?
2. I will still need to remove the tool probe a couple times a year, is there a quicker method to putting it back than eyeballing it close then doing a full calibration?
3. After recalibrating everything will I have to go through and reteach all the tool lengths to keep everything lined up?
