Buttress Thread Help Measuring
metx
Jan 27, 2011
texas, USA
Hello all,
Could someone please help me with measuring an American Buttress 45/7
OD thread?
The thread data: 6-3/4"-3N Buttress-2ASA, RH
Major diamer 6.7267-6.7407"
Pitch Diamter 6.5934"-6.6074"
Minor Dia. 6.343"-6.4034"
I need to know what size wires and measurment over the wires for PD
I came across a formula online the find best wire size and come up with
.18049" Can this be verified also.
Thank you for any help.
Metx
Thanks Gordon,
I don't know why the data on the print I have is different from standard size. I have a sample part and will measure PD on it with .180" wires and I guess make the new parts to match it or a little smaller.
If I had a lot of threads like this would check into FMS system. I been on their website checking them out. Nice and seems affordable way to measure with out expensive gages.
Keith
Keith,
Any chance you can post a picture (when you're finished) of what you're making that uses that thread?
Buttress threads fascinate me. If I remember correctly it was a Texan that got me started on them :)
Gordon
Added: My memory is correct :cheers: Buttress threads have turned out to be more used than I thought. Most are 7º/45º.
I haven't seen 3N or 2ASA on a blueprint before, and can't find them in the standard or by using Google. If it was my job, I'd be on the phone to the customer. It could even have a modified thread form.
Probably shouldn't have but I took the 3 to be TPI (looked plausible from the diameter) and the 2A as the tolerance. It was an external thread and 2A is an external tolerance.
Buttress-2 ASA - Google Search
Seems to be an old type Buttress thread.
Screw-thread Standards for Federal Services, 1957 - United States. Interdepartmental Screw Thread Committee - Google Boger
You're right. Not wise to start before contacting the customer. Even a 7º/45º Buttress thread has profile variations. Same with Stub Acme - more than one standard. Not a problem I have as what I make measures only pitch diameter.
Re Stub Acme then ½ height Acme is the most common but there are also 1/3 and 1/4. ASME/ANSI B1.8
Mike, you must be as daft as I am to be just as interested in threads as I am :)
Likely all true, but we both know better than to assume anything. The oddball diameters and designations might well be accompanied by other "special" features.
