ballen
- Sep 25, 2011
- Garbsen, Germany
I have couple of Mitutoyo bore gauges that always bring a smile to my face when I use them. One is 18-35mm and the other is 35-60mm. They have a three-point device at the end, and then a long plunger-in-a-handle and at the top is a dial indicator. You set the zero with a micrometer, then gauge your bore. It makes it easy to match a shaft and a bore to a few microns.
Anyway, for a while now I have been looking out for a smaller set, to cover 10-18mm. This turned up on Ebay a couple of weeks ago, with an inaccurate description. I was the only bidder and got it for 29 Euros including shipping:
It just arrived tonight. When I opened it, I found that it has never been used. The feeler fingers still had the factory wax protective coatings (which I have removed in the photo above). All the accessories are there, including the extension bar, the holder to keep this at a fixed distance from the mouth of the bore, etc. There was a brown sheet of VPCI paper inside, so nothing is corroded. The indicator is 2 microns/division, and runs as smooth as could be. The shiny parts are ground and polished steel, the darker parts are blued steel (apart from the hand grip, which is dense rubber foam to isolate it from hand heat). The instruction manual dates this from the DDR (former East Germany) in 1989. And all of this in a perfectly-crafted finger jointed box with a molded foam rubber fitted lining.
I'll get to use this soon because I have to turn a 4-step pulley from some cast iron, and need to match the bore closely to the motor shaft.
