Cast Iron Surface Plate
Results 1 to 4 of 4
    Mar 2020
    CANADA
    Alberta
    Default Cast Iron Surface Plate
    A friend of mine made me a 16" diameter by 2" thick cast iron surface plate. It was supposedly lapped "optically flat". It has a mirror bright finish. I have not checked the flatness of the plate myself.
    The question I have is should I work with this plate or buy a cheap granite plate? It is for an armature home shop.
    If I do use it what do I have to do for the use, care and maintenance of a cast iron surface plate?
    Jul 2006
    Hillsboro, New Hampshire
    8,970
    2151
    6220
    Quote Originally Posted by BigAl666 View Post
    1) Don't get it wet.
    2) Don't feed it after midnight.
    Welcome to PM. We have no idea how flat your plate is (shiny does not equal planarity), and CI is subject to dings, rust, etc. So save that plate until you can get it measured and buy a cheap granite surface plate, even the CN B-grade plates are typically pretty good.
    Granite is a better "rubbing" surface in many instances when using height gages and the like, so they'll move more smoothly than on a CI plate.
  3. Likes eKretz liked this post
    Jan 2003
    Columbia Missouri
    816
    40
    130
    Does your friend make telescopes? If so, he may be able to tell you just how flat it is- and it is likely far more flat than what you need- but that is what you want. Having a surface that is less accurate than claimed or needed is a problem.
    I would get an inexpensive plate to use for "close enough" noncritical work, and save the good plate for when it is needed.
    Be aware that if you lay the lapped surface down against another lapped surface the air will be forced out. As this occurs the surfaces will easily slide- but after they are fully touching they will be very difficult to separate.
    Jul 2007
    Missoula Mt
    285
    7
    101
    Its probably not worth a damm, It would need to be a lot thicker to hold its flatness, and it takes a very good stable grade of cast for a surface plate, I have one that is 18x24 and it is webbed and 6 inchs thick, 450 lbs. Your plate would be all over the map with a change in temp. Find a pink stone....Phil
  6. Likes Janderso liked this post
