Digital hardness tester
Lanza
Jun 22, 2007
Western Australia
Looking to hear from people that have experience using the digital hardness tester.
I have attached a link. It does Leeb, Brinell, Rockwell A,B,C, Vicker, Shore.
Will this tool assist me in anyway for a unknown piece of material. I reproduce a lot of pin and shafts.
Q520 - 50-520 Portable, Digital Hardness Tester | Hare & Forbes Machineryhouse
I'm aware of the usual test such as looking at the swarf colour and also two pieces hit together on the edges to compare harness as a comparator.
Bought the exact same one off of Amazon a couple months ago for about $250. So far, I'm impressed with the accuracy of the unit. I don't see this unit as something you turn loose in the shop for anyone to use. It does come with a massive piece of harden steel that is accuractly made for calibrating the unit to. I would say if your measurements are in the 50-65 HRC range you are probably good using this instrument. For any hardnesses lower than this, suggest getting the proper test blocks to calibrate the unit to IMO. Overall, I like it . Ken
Edit: I don't think this unit would be good for checking the hardness on small shafts. You have to have a flat at least 1/8" wide to get the instrument to set firmly to trigger the ball to hit and record. And this would be iffy on such a small shaft. The shaft would also have to set solidly on a larger piece of flat metal for it to transfer a good signal to the unit for a accurate reading. Another reason for test blocks needed for the exact hardness needed to test to, to validate your readings.
I cant help you with the digital stuff.
But I use these files to check for hardness and they work great for me.
Hardness Testing File Set: Hardness Testing Apparatus: Amazon.com: Industrial & Scientific
