Find CMM services, or buy a probe??
Likes Likes:  0
Results 1 to 6 of 6
    Jan 2007
    Southern New Hampshire
    1,315
    988
    482
    Default Find CMM services, or buy a probe??
    I have a small shop, with a SHARP SV2412S machining center and Haas TL-1. I am talking to a client about making a prototype which will have a parabolic surface (we design antennas) which will need to be accurate to about 0.002-in. in aluminum. This surface will be made on the lathe.
    I am thinking about the inspection process, and how we will verify the surface.
    Would you recommend securing contract CMM services for this type of work?
    If I take the part off the lathe and put it on the mill table, can I probe it, assuming I buy the right probe? (The SHARP's specs are +/- 0.0002-in in position)?
    What would you recommend?
    May 2006
    NC
    679
    40
    31
    What is the size of the part and how much are you willing to spend?
    Nov 2005
    Maryland
    8,201
    746
    1104
    What are we talking about here, like an 18" dish for X-Band?
    IMHO that tolerance is absolutely ridiculous for an antenna if it's to be used outdoors.
    - Leigh
    Jan 2007
    1,315
    988
    482
    Initially, the size is 9-10 inches in diameter, thickness not yet determined. And yes, the required tolerance is about +/- 2 mils.
    I had a nice conversation with Renishaw, and a system that would integrate right into my SHARP VMC is about $11K. For this first project, that's too much.
    (Oh, and Leigh: this ain't consumer junk.)
    Oct 2008
    NY
    684
    14
    107
    You're talking about a spherical surface? I can slap it on our Zeiss Contura and take tens of thousands of scanning points. We charge $100 an hour for that machine for outside work. If the only thing you need inspected is that surface, I can't see it taking more than an hour. Just a thought...
    Jan 2007
    1,315
    988
    482
    Quote Originally Posted by StreetSpeed View Post
    And a fine thought that is!! Shoot me a PM with your contact info, please.
